Old 03-18-2013, 10:53 AM   #1
makecopies
My Ride: Gods Chariot
Unhappy Not sure if clutch or what?
I have a 325Ci when im shifting from 2nd to 3rd revs go high but almost to 5 grand car barely moves its slower than ever now.
But I can pull away from a complete stop in 2nd or 3rd gear. I thought that was the test for a dying clutch.
Stealer said I needed a lower intake boot last summer because of a small crack. I haven't really driven the car since.
Can a crack in a lower intake boot cause such off acceleration?
I have no codes on my Peake reader.
makecopies is offline   Reply With Quote
Old 03-18-2013, 10:55 AM   #2
My Ride: 2016 Lexus
probably clutch. takes more friction/pressure to hold at speed
Old 03-18-2013, 11:07 AM   #3
makecopies
Damn
Old 03-18-2013, 11:08 AM   #4
WDE46
My Ride: 2004 330Ci OBM
Speed should correspond to engine rpm. A vacuum leak won't change that. If the engine was making no power, it would just accelerate slow at a normal RPM. Clutch slip will give you the unusally high rpm.
A clutch is a maintenance item. Don't be disappointed that you need a new one. >100k miles, it's not really a surprise.
Old 03-18-2013, 11:16 AM   #5
makecopies
Does anyone know how much I should be looking at to have the clutch replaced on a 2001 325CI?
Dealer or Indy?
Old 03-18-2013, 11:41 AM   #6
mtnbound
Town Clown
My Ride: 330Ci Vert, 325iT
*cough* *cough*
http://forum.e46fanatics.com/showthr...ghlight=clutch
Bay Area Top Dropper
Orient Blue 330 Ci Vert
mtnbound is offline   Reply With Quote
Old 04-10-2013, 01:51 PM   #7
echoes
My Ride: 2002 330Ci
Same issue with mine
Instead of starting a new thread, i'll say I'm having the same issue. Also high RPM gear 2nd > 3rd will do that same thing for me but it more noticable from 1st > 2nd.
I have a 2002 33Ci with 95K. You think I just need a clutch? Sachs okay? Should I order any tools for DIY? I've seen an alignment took on ECS Tuning for this. Doubt it's critical though.
echoes is offline   Reply With Quote
