///M3 Forum
Old 03-18-2013, 10:46 AM   #1
helmutm3
My Ride: 04 m3
Window/door problem
So it looks like the "party" has started for my BMW. After owning it for 5 months and only at 50k miles it developed an issue. Looking to see if anyone has any pointers on how to fix it before I have to take it to a shop and get raped.
Problem:
The dash indicator shows that the passenger door is open. Therefore the passenger window doesnt go all the way up. Its like that 75% of the time altough sometimes it turns off, window goes up and all is good for a while. There are times where the door light keeps going on/off constantly . I am guessing its a sensor. Did anyone have this problem and fixed it on their own ? Thanks.
helmutm3 is offline   Reply With Quote
Old 04-09-2013, 10:06 PM   #2
tinchomermoz
My Ride: 02 M3 Convertible
Same here
i am having the same problem. it's with my drivers side door. about 2 months ago I replaced my door's lock actuator because the motor was getting weak and it stopped locking the door. Now im thinking this new actuator (OEM) has failed. I am not sure if the GM5 module could be causing this.. I don't think so. if the dash indicator says door is open and the window won't go up all the way, then the sensor in the door lock actuator has failed and there is nothing you can do to repair it since its a sealed unit. Any thoughts?
2002 BMW M3 Convertible (my DD)
2012 AUDI Q5 2.0T (wifey's)
1998 BMW R1100RT
2006 BMW K1200R
2001 BMW 330ci (sold)
tinchomermoz is offline   Reply With Quote
Old 04-10-2013, 07:16 PM   #3
helmutm3
My Ride: 04 m3
Thanks. At this moment all is good. I havnt had the problem reoccur in weeks. I hope it stays this way for a while.
Old 04-10-2013, 09:17 PM   #4
tinchomermoz
So did it just fixed itself?? i read some people use WD40 with good results.. it didnt work for me... as i said, mine is a brand new lock.
1998 BMW R1100RT
2006 BMW K1200R
Old 04-11-2013, 05:17 AM   #5
helmutm3
My Ride: 04 m3
Yeah, it stopped acting up on its own, so I got lucky. (at least for now)
