Sponsored by BimmerWorld
Old 03-18-2013, 12:08 PM   #1
hitmanre
My Ride: 2000 BMW 328i
looking for rotors
I want to get drilled rotors for my e46. Im thinking zimmermanns but where can i get them at lowest price for my 2000 328i?
hitmanre is offline   Reply With Quote
Old 03-18-2013, 12:20 PM   #2
Zell
Zell's Avatar
My Ride: so turbo wow
You can get the ECSTuning rotors for less if you want.
http://www.ecstuning.com/BMW-E46-328...ors/ES2190216/
Old 03-18-2013, 12:40 PM   #3
hitmanre
you think its as good as zimmermann?
Old 03-18-2013, 12:44 PM   #4
Guest021715
Account closed.
Don't get drilled, they only create problems.
OEM blanks are best.
Old 03-18-2013, 12:45 PM   #5
choxor
My Ride: JDM
Old 03-18-2013, 12:48 PM   #6
Hockeyguy02
My Ride: E46 m3
How about slotted ?
CarbonBlackCinnamon
30% Tint/Black Grilles And Gills/CF Wrapped Trim/MeganRacingExhaust/DepoSmokedCorners
Hockeyguy02 is offline   Reply With Quote
Old 03-18-2013, 12:52 PM   #7
limpiabota809
My Ride: 330 XI
http://www.rockauto.com/catalog/more...124&cc=1358265
Front set of powerstops (drilled and slotted) for 48$
http://www.rockauto.com/catalog/more...519&cc=1358265
Rear set of powerstops (drilled and slotted) for 49$
They also have a combo for all 4 rotors and pads for 270$
http://www.rockauto.com/catalog/more...331&cc=1358265
Instagram - @Limpiabota_e46
limpiabota809 is offline   Reply With Quote
Old 03-18-2013, 12:54 PM   #8
My Ride: Lexus
But the ppl need superior braking power yo. they want dat xtreme braking effect when stomping on the middle peddle. or in most cases, da left peddle
Old 03-18-2013, 12:55 PM   #9
limpiabota809
My Ride: 330 XI
Can you please tell me what are the issues created? I just changed mine and got blanks but I like the way drilled and slotted look. Just so that I would know what the problems are?
Old 03-18-2013, 12:57 PM   #10
choxor
My Ride: JDM
Drilled rotors are more prone to cracking. Drilling and slotting also reduces the surface area of the rotor. Modern pad compounds make slotting and drilling pretty much pointless for daily driving.
For track use there may be advantages to slotted rotors.
Old 03-18-2013, 01:04 PM   #11
Guest021715
Account closed.
^ What he said.
Add to that list rust (usually a precursor to cracking)
I donít remember which vendor it was, but they posted a thorough comparison of rotors for the E46, and explained how drilled/slotted rotors are pretty much entirely for looks.
Even a quality slotted rotor like the ATE PremiumOne causes shudder and vibration under moderate to high braking, as Iíve personally experienced on more than one car.
Old 03-18-2013, 01:09 PM   #12
limpiabota809
My Ride: 330 XI
Thank you very much guys, OP sorry to thread hack but I'm pretty sure that piece of info was pretty useful to you
Old 03-18-2013, 01:50 PM   #13
ModBargains III
ModBargains III's Avatar
My Ride: E46
I've got drilled replacement rotors from StopTech right here if you'd like to take a look:
Drilled StopTech Direct Replacement Rotors BMW 328 Series (PAIR)
If you have any questions, don't hesitate to ask! You can reach me over PM/email or you can call at 714.582.3330 extension 8002!
Sean S. | Sean@ModBargains.com |(714) 582-3330 ext 8009
We Specialize In: BMW Brakes | BMW Suspension | BMW Parts | BMW Exhaust Experts |
BMW Wheels In Stock | BMW Intake Experts
Hours
Check out our Blog for updates & discounts!
ModBargains III is offline   Reply With Quote
Old 03-18-2013, 03:04 PM   #14
ECSTuning
ECSTuning's Avatar
My Ride: BMW
http://www.ecstuning.com/BMW-E46-328i-M52_2.8L/Braking/Rotors/ES2190216/
I have a ton of guys running our ECS GEOMETs and everyone loves them. The protective coating helps keep them looking good year around, and the design helps keep you cool in extreme braking situations.
Feel free to shoot me a PM if you need help with anything or have any questions.
Old 03-18-2013, 03:10 PM   #15
WDE46
My Ride: '13 128i, '04 330Ci
Nothing wrong with some name brand drilled or slotted rotors for an aesthetic upgrade. Just don't expect to gain ANY performance whatsoever because of it. The cracking problems are from poorly made rotors, or ones that were originally designed as blanks and then drilled for looks. If you get rotors from a good company (like Zimmerman), then the rotor was designed with the holes in mind.
I use Zimmerman blanks and ATE pads. Couldn't be happier.
Old 03-18-2013, 03:43 PM   #16
hitmanre
Thanks guys^ I think im going with zimmermann rotors since as above comment said " (like Zimmerman), then the rotor was designed with the holes in mind." but the question is where can i get them?
Old 03-18-2013, 04:22 PM   #17
ECSTuning
ECSTuning's Avatar
My Ride: BMW
I have the drilled fronts available HERE and the rears available HERE from Zimmermann. Please excuse the terrible photos of the rears I just noticed how bad they are, I'll have my guys re shoot them soon.
Old 03-18-2013, 04:52 PM   #18
hitmanre
you guys do price matching or FS? because i realized bmaparts quoted me for 328 shipped.
Old 03-19-2013, 02:10 AM   #19
Phattcatt
My Ride: 2003 330 xi
Key to remember is quality parts but !!!! Brake fad is why drilled and slotted rotors were created. I'm a mechanic and we have been doing some researching the subject. Most think it is heat alone that causes fad but it is heat that creates what is called " gassing" this forms between the friction materials ( pads and rotors ) and it is this gassing that greatly reduces the co-efficient of friction. Drilling and/or slotting of the rotors dissipates this gassing greatly improving hard repetitive braking! Before disks drum brakes had the expanding drum and gassing together to create the most fad in braking. Although surface area is important it is a minimal loss of surface area compared to the efficiency created. Although most driver I see don't drive hard enough to ever notice much difference, and only think they look cool like the bright red callipers! Yuk!
Lol hope this helps people out when I burn thru my brakes I will be looking for some quality rotor kits. Drilled and slotted of course!
Phattcatt is offline   Reply With Quote
Old 03-19-2013, 03:37 AM   #20
hitmanre
I just ordered zimmermanns what you think of em?
