Old 03-18-2013, 02:46 PM   #1
venzon
My Ride: 04 zhp 6MT
Car will not stay running
I searched and can't find exact symptoms. 2004 330i zhp, the engine was warm. Car started but will not stay running if I let go of the gas or even press the gas. The engine will not rev when I press the gas. After a few tries, everything is good. These happened on two separate occasions. This problem only happens after start up. I have now driven 160 miles and issue has not reoccur. No CEL or fault codes found. Is this a sign of failing fuel pump or something else? I'm planning on doing engine tune up.
venzon is offline   Reply With Quote
Old 03-18-2013, 02:55 PM   #2
benzedid
My Ride: 2001 BMW E46 318i
Looks more like a dying fuel pump.
benzedid is offline   Reply With Quote
Old 03-18-2013, 02:59 PM   #3
WDE46
My Ride: '13 128i, '04 330Ci
pressure test the fuel rail.
Old 03-18-2013, 03:13 PM   #4
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Look into your battery/alt too.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 03-18-2013, 03:41 PM   #5
E46Moonlight
My Ride: 2000 323i
Ill put money on the fuel pump!
E46Moonlight is offline   Reply With Quote
Old 03-18-2013, 03:42 PM   #6
jfoj
My Ride: 330CiC, M5, X5, E93
Check codes.
Look at the first links below in my signature.
