Old 03-18-2013, 02:57 PM   #1
comova
My Ride: Silver 325Cic
Valve Cover Gasket - Part Deux
Threaded Studs (11121718856) have been ordered; Cap Nuts (11121738608) have been salvaged- using a small screw driver I was able to thread-out broken studs. Props to my mechanic for this trick; & I have the proper torque settings.
Now my *final* question:
Gasket has been sitting on car for 2 days now with the (Red RTV High Temperature) silicone, do I have to remove and add new RTV or am I OK just torquing it down?
Thanks in advance.
"The problem with the designated driver program, it's not a desirable job, but if you ever get sucked into doing it, have fun with it. At the end of the night, drop them off at the wrong house." -Jeff Foxworthy
comova is offline   Reply With Quote
Old 03-18-2013, 03:01 PM   #2
dwsounddesign
My Ride: 2002 BMW 330xi
keep an eye on it for a few days. If it still leaks, slowly, re-torque but not over torque it or it will crack
dwsounddesign is offline   Reply With Quote
Old 03-18-2013, 03:01 PM   #3
WDE46
My Ride: '13 128i, '04 330Ci
what do you mean? at least link your original thread, or don't start a new one.
Old 03-18-2013, 03:11 PM   #4
comova
@WDE46: Since this is a whole new question I decided to start a different thread. The original thread was regarding torque and titled wrong (http://forum.e46fanatics.com/showthread.php?t=976545)
My new questions is "do I have to remove" the old silicone or not.
@dwsounddesign: Nothing is torqued down at the moment, just loosely hand tightened.
Old 03-18-2013, 03:27 PM   #5
choxor
My Ride: JDM
Personally, yes, I would. The idea is to have the RTV fully set with the VCG properly compressed to compensate for odd areas like sharp edges or gaps. It sounds like it didn't.
choxor is online now   Reply With Quote
Old 03-18-2013, 03:28 PM   #6
WDE46
RTV needs to cure after torquing. Where did you apply RTV? Did you torque the rest of the bolts around the outside? If so, then the outside gasket RTV is fine. If you put RTV in an area and then let it cure without torquing the surrounding bolts, you should do it again.
Old 03-18-2013, 03:36 PM   #7
BeMyWhip
My Ride: 01 BMW 330ci
This is just stupid talk.
You remove the old gasket, clean both mating surfaces very well, and apply the silicone only in the half moon areas. Period.
Do you put on a suit after working on your car without a shower?
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
Old 03-18-2013, 03:51 PM   #8
WDE46
I think you misinterpreted. It's not as stupid as you think. OP put on a new gasket. He then overtorqued a nut and broke a stud. The new gasket sat on the head with the new RTV for a while and without being torqued down. At least that's my understanding.
Old 03-18-2013, 04:09 PM   #9
comova
You are 100% correct. Threaded stud is in the mail. Thanks for the comments guys I will remove today and clean off old RTV. I'm assuming that will just peel off.
Old 03-18-2013, 04:20 PM   #10
BeMyWhip
yes, very easily. You need to remove everything to remove the stud, so just do the job over. GL
Always Mod!!!
Old 03-18-2013, 04:28 PM   #11
WDE46
aye redo it now so you don't have to do it again later when you see it's leaking anyway.
Old 03-18-2013, 04:30 PM   #12
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
The rtv you sprayed on the gasket won't come off easily...not that I recall. If you sprayed the gasket, I think you'll be fine spraying it again...making sure the head surface is clean...adding ultra black (or another tube rtv) to the half moons and where vanos meets head)
Upcoming comedy shows: May 20, Greenwich Village Comedy Club. 6 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 03-18-2013, 04:40 PM   #13
comova
I used my finger and dabbed it on the half moons
silicone, torque, valve cover gasket
