Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 03-18-2013, 05:50 PM   #1
tonyisok
My Ride: 323i Sedan
Steering Rack or Tie Rod End Boots
I'm looking for the older version (Cone Shaped) of the Steering Rack Boots....Not the ones that have large opening at both ends with the doughnut rubber fitting on the outter tie rod end.
If someone knows the part number or where I can purchase the older version of these rubber boots/dust covers I would greatly appreciate the info.
tonyisok is offline   Reply With Quote
Old 03-18-2013, 05:52 PM   #2
///MPR77
My Ride: 323i ZSP/ZPP
did you check http://realoem.com?
Originally Posted by ///MPR77 View Post
Some say his notoriety is so profound, that he was able to drop the e46 in his name, and just like "The Highlander" there can only be one....all we know is he is called "Mango"
///MPR77 is online now   Reply With Quote
Old 03-18-2013, 05:58 PM   #3
lcoleman
My Ride: '79 Massey Ferguson
...why? The new version is just as good, and can be installed without needing an alignment.
Old 03-18-2013, 06:28 PM   #4
tonyisok
My Ride: 323i Sedan
Seems when with these their either full of air or are overly compressed and flat and wont stay in the indented area of the tie rod end...
Old 03-19-2013, 06:42 AM   #5
paraklas
paraklas's Avatar
My Ride: ESS TS2 320ci
I installed the new ones with the collars etc and never had such issue of not staying in place. Maybe not tight enough?
http://www.argyrides.eu/makeyourownsig.jpg
paraklas is online now   Reply With Quote
Old 03-19-2013, 10:48 AM   #6
tonyisok
My Ride: 323i Sedan
I had them tight and when I turned wheels all the way left or right the boot would seem to be over filled with air or looked deflated and flat...instead of like an accordian like it did with the original boots. I ordered new clamps; see what happens...thx
Old 03-20-2013, 08:04 AM   #7
tonyisok
My Ride: 323i Sedan
If someone has the older version of these boots (the ones with the small opening on one end that fits around tie end) could you send me the part number? If someone has a set in good condition PM me and Thanks
ID:	496349   Click image for larger version
ID:	496350   Click image for larger version
Old 03-20-2013, 08:31 AM   #8
lcoleman
I think you have the wrong part #, or you installed them incorrectly (too stretched out). I was looking yesterday, I have these and no issues.
