Old 03-18-2013, 06:54 PM   #1
hitmanre
My Ride: 2000 BMW 328i
headlight problem
Okay so I tried 2 bulbs in my driving lights and when i start the car sometimes a error comes up for the light but than it goes away. and than the light isnt as bright as the other light? the bulbs are the same btw
hitmanre is offline   Reply With Quote
Old 03-18-2013, 06:55 PM   #2
Broach><330
My Ride: 330CI -E30 325 (S52)
Your ballast is going out, just get a new ballast. Or swap in a known good ballast and see if you see a difference
High-line catback
Kosei K1's
Headers
3.15 Differential
Koni FSD, eibach sports
AA software
205k (9/16/13)
E30 S52B32 100,xxx
5spd ZF, JB LW fly, Megan Coils, OBD1 conv. Mishimoto with low temp stat, TRM 15x8, Black vinyl sport seats, MOMO mod 08, 2:93 LSD, Custom single 2.5" exhaust, SS headers, M3 rack, basically new everything on driveline.
Broach><330 is offline   Reply With Quote
Old 03-19-2013, 01:39 PM   #3
hitmanre
I have plain halogen bulbs. No xenons
Old 03-19-2013, 01:53 PM   #4
effay
My Ride: 323Ci
then its time for a retrofit. get a hid wiring harness in the process and be happy with new xenons
effay is offline   Reply With Quote
Old 03-19-2013, 03:18 PM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Do you have any corrosion on the socket?
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 03-22-2013, 11:59 AM   #6
hitmanre
Nope I don't see any :/
Old 03-23-2013, 04:23 PM   #7
sillieidiot
My Ride: '06 AW 330ci
check your ground on the headlight plug. the side with the dimmer bulb. usually a dim bulb suggests a bad ground.
