Old 03-18-2013, 08:11 PM   #1
daewon774
My Ride: 2002 330xi
Exclamation Stuttering when WOT, AA stage 1
I having an issue with my e46 330. I have a stage 1 AA kit installed. I was getting a ICV mechanically stuck open from the ECU, and then got it replaced. The car now drives fine under light to medium throttle, but when at wide open I'm getting issues.
  • When at WOT at around 2800 RPM and after, the car stutters. It goes through the revs, but you can feel the motor stutter, and the exhaust sound is not 'even'. There's a big change in the way the motor behaves and sounds. If I let off, the car drives fine from light to medium throttle.
  • Also, if I do two or more runs at WOT, the car then stutters constantly even at light and medium throttle. When I key off for ten seconds and then key on, the car will act fine from light to medium throttle again.
Any ideas on how to diagnose and see what the issue might be?
2002 E46 330xi
Active Autowerke Stage I Supercharger
Magnaflow 11378 exhaust
Bilstein shocks/struts + H&R springs
Style 71s
Soon to be installed Bimmerbrakes headers + LC1...
daewon774 is offline   Reply With Quote
Old 03-18-2013, 08:41 PM   #2
TrippinBimmer
My Ride: Just Fast!
Test all ur injectors. I assume this happen under load?
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 03-18-2013, 08:44 PM   #3
daewon774
My Ride: 2002 330xi
Exactly, all under load.
Mind if I ask what the procedure is to test injectors? What do you mean? Flow?
2002 E46 330xi
Style 71s
Old 03-18-2013, 09:09 PM   #4
TrippinBimmer
My Ride: Just Fast!
I use a 9v battery and make sure all noid opens. I had an issue with one of my injectors just failed on me. Then if they all open then do a flow test...
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 03-19-2013, 09:15 AM   #5
daewon774
My Ride: 2002 330xi
Thanks again for the reply. When you mean 9v battery, you mean a standard 9v rectangular battery like these?
2002 E46 330xi
Style 71s
Old 03-19-2013, 09:30 AM   #6
Viral@ActiveAutowerke
Past Site Sponsor
My Ride: E46 M3
Please give us a call that way we can help diagnose this issue and point you in the right direction.
Viral@ActiveAutowerke is offline   Reply With Quote
Old 03-19-2013, 09:41 AM   #7
TrippinBimmer
My Ride: Just Fast!
Yep, injectors don't need to much voltage.
BTW: I would not drive the car until you know what's up. Probably have engine damage...
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 03-19-2013, 10:16 AM   #8
SweTurbo
Big Pimpin'
My Ride: 323i -98
This, what you're feeling is knocking.
Old 03-19-2013, 11:58 AM   #9
mike@maximumpsi
My Ride: 02M3T
I would start by checking the codes for a misfire. It sounds ignition related since the issue goes away under light load. Make sure to have a good set of plugs installed and gapped correctly. If you have a weak coil it could have issues in boost. A simple way is if you are having cyl 3 misfire, swap coil # 3 and 4 and see if the misfire moves to cylinder #4.
02 M3 - Maximum PSI S2 turbo kit - 9.74@145.99, stock motor, stock ECU, first in the 9's
97 M3 - Maximum PSI turbocharged - 8.94@164.33, stock ECU, first in the 9's, first in the 8's
16 M3 - Maximum PSI full bolt ons - 10.27@137, quickest in the US
BMW SOB's turbo E30 - 8.72@158.39
Maximum PSI - Home of the quickest BMW's in the US
Click here for E46Fanatics 1/4 mile standings
Follow us on Facebook and Instagram!
mike@maximumpsi is offline   Reply With Quote
Old 03-24-2013, 12:37 PM   #10
daewon774
My Ride: 2002 330xi
I just wanted to post up my results in case anyone else runs I to a similar problem. I had a code F2 which is a misfire of cylinder 5
Swapped injectors with cylinders 5 and 6 = everything fine
Swapped coils = everything fine
Swapped spark plugs = problem followed the plugs!
I took a look at the plugs and there was a huge crack I didn't see whn I swapped the plugs. Got new plugs and everything is fine
Thanks everyone for all the comments and suggestions!
2002 E46 330xi
Style 71s
Old 03-24-2013, 01:32 PM   #11
TrippinBimmer
My Ride: Just Fast!
Kewl beans
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
