///M3 Forum
Old 03-19-2013, 01:30 AM   #1
jmanhas
My Ride: BMW M3
Help me diagnose my engine misfire :(
Hey guys, I've done hours and hours of research before making thisthread.
Codes I am getting0300 P03003 P03004 p03005 p03006
Symptoms: cold start idle hunting, feels like iit's about to stall sometimes, once warm it seems fine. somewhat bad fuel economy
jmanhas is offline   Reply With Quote
Old 03-19-2013, 01:33 AM   #2
jasmit56
My Ride: E46 320i
O2 sensors only start doing there Job once the car heats up.. Could be your fuel pump or vanos seals.
jasmit56 is offline   Reply With Quote
Old 03-19-2013, 02:10 AM   #3
jmanhas
My Ride: BMW M3
if it was my fuel pump, from what i read, there are two types of failures. Soft failure = car will die even with half tank of gas on the gauge. Or Hard failure = where my car will just die out of nowhere. Unless i am mistaken..
do vanos seals cause engine misfire??
Old 03-19-2013, 04:44 AM   #4
jasmit56
My Ride: E46 320i
Vanos seals generally will lead to bad idle, car hesitating to stay alive at low rpm etc..
Old 03-19-2013, 08:56 AM   #5
choxor
My Ride: JDM
This is an M3.
OP, translate those codes. We're not going to google each of them.
Old 03-19-2013, 01:07 PM   #6
jmanhas
My Ride: BMW M3
The P0300 is multiple cylinder misfire, and p0300 etc is misfireon each cylinder number. I p0171 and p1074 is running llean
Old 03-19-2013, 06:18 PM   #7
jasmit56
My Ride: E46 320i
Originally Posted by choxor View Post
This is an M3.
Oh shii.. Sorry totally missed the fact it's an m3...
Old 03-19-2013, 06:22 PM   #8
jhaurimn
My Ride: 01' 330ci
Lean mixture codes is an air leak. Somewhere in the intake most likely. As far as your misfire, did it start after you changed your coils and plugs ? Did you use oem coils? What's plugs did you use?
Edit after reading again, it *possibly* could be the fuel pump causing the lean codes. If all the coils and plugs check out, I might consider that.
PAST
2001 330ci - 117xxx (sold)
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
jhaurimn is offline   Reply With Quote
Old 04-03-2013, 10:21 PM   #9
jmanhas
My Ride: BMW M3
Ok, so afte everything, I'm still getting misfires. I've made sure all coils and spark plugs were correctly fitted. Also installed the rebuilt vanos solenoid from Besian systems. Cleared codes and my car still misfires. I'm not sure what else it is...
Old 04-04-2013, 07:08 AM   #10
evilpinkeye
My Ride: E46 M3
Fuel delivery acting up on you maybe?...still maybe fuel pump. How did you check for air leaks? Sprayed carb cleaner around to see if idle changes on you?
Man hope you find out what's wrong...
evilpinkeye is offline   Reply With Quote
Old 04-04-2013, 03:31 PM   #11
jmanhas
My Ride: BMW M3
So I took apart the engine cover and made sure all connections were good. I took out spark plugs and re installed them as well as the coils. It seems to have fixed the issue for now. I'll report back after another few days!
Old 04-04-2013, 03:57 PM   #12
taylor192
My Ride: 2003.5 M3
Did you read the BMW codes? My Peake reader will tell you more than just the ODB codes.
Old 04-04-2013, 03:58 PM   #13
jmanhas
My Ride: BMW M3
Noo I didn't get the BMW codes read. Are you back in town??
Old 04-04-2013, 05:58 PM   #14
taylor192
My Ride: 2003.5 M3
Back with a tan and bottles of tequila! Stop by the office after 2 tomorrow and I can read the codes, txt me first.
