Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Mid Atlantic
Mid Atlantic
DC DE MD PA VA WV
Old 03-19-2013, 10:41 AM   #1
makecopies
My Ride: Gods Chariot
Clutch replacement recommendations & price
For a 325ci?
makecopies is offline   Reply With Quote
Old 03-22-2013, 07:51 PM   #2
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
Going with a single-mass flywheel will cause transmission chatter whether you use the Redline mix/run a sprung hub or not. If you want OEM quietness/smoothness, go with a new OEM dual-mass flywheel and clutch kit. Don't forget to do the pilot bearing, throw out bearing, rear main seal, input shaft seal, and pivot pin. It's also a good opportunity to do the shift detent bushings/springs, which fixes the 5th gear lean.
Chris
dreamdrivedrift is offline   Reply With Quote
