E46 Convertible
Old 03-20-2013, 10:13 AM   #1
Chiefriley
My Ride: 2001 imola red 325ci
top wont operate with engine running...
...help, top wont operate with engine running...new here i know i've asked before but when i bought the car the dealer told me (when he) part exed it the battery went flat, he then said he put a new battery in... so i don't know if the 2 are linked
bit worried as people are saying DON'T operate the soft top without the engine running as it could flatten the battery...seems a coincedence..
could it need re-setting?
please help
ta very muchos
S
Chiefriley is offline   Reply With Quote
Old 03-20-2013, 10:52 AM   #2
sgoetz628
My Ride: 2002 330 CiC
please help
ta very muchos
S
Something could use fixing, as the top should operate w/ engine running or not. However, do not hesitate to operate the top w/ the engine off.
First, it's designed to operate w/ the engine off, as you can control it from the driver's door. What makes this especially nice is that you can open the top before getting inside. On a hot day, this allows the heat to escape, which I presume was one of their intentions.
Secondly, I frequently operate the top with the engine off and my OEM battery lasted 9 1/2 years!
So don't let some ignorant advice worry you, you're good!
I love my car as much today as the day I bought it
sgoetz628 is offline   Reply With Quote
Old 03-20-2013, 10:59 AM   #3
Chiefriley
thanks sgoetz628 really appreciated, i will look into what the fix may be and nice to know it can be operated, however after reading your reply I'm debating whether to install a, OEM battery as I'm sure the dealer won't have....
thanks again. )
Old 03-20-2013, 11:53 AM   #4
TopHydraulicsInc.com
Supporting Vendor
TopHydraulicsInc.com's Avatar
My Ride: German verts
Thumbs Up operating the top without engine running
I do not have an answer to the original problem posed, but would like to chime in on using pumps without the engine running. I don't want to step on anyone's toes, especially not being a BMW owner myself, but would agree with sgoetz628.
The hydraulic pump draws some 20A. If it runs for some 30 seconds under normal conditions, then this would be using about 1/6 Ah of the battery's capacity - on the order of 1% of a new battery's capacity (forgive me for rounding off here). If that "flattens" an old battery, then it is time to swap batteries.
Klaus
www.tophydraulicsinc.com
Some BMW E46 hydraulic cylinders, pumps, and valves that we rebuild and upgrade at Top Hydraulics:
54347025593
54347025600
54347025599
54348236956
54348243269
543454347025595 (hydro-unit, sticker p/n is 8234530)
54347025592 (control unit)
54347025598 (improved hoses manufactured at Top Hydraulics)
http://www.tophydraulicsinc.com/en/56-bmw-e46
TopHydraulicsInc.com is offline   Reply With Quote
Old 03-20-2013, 02:32 PM   #5
Chiefriley
Thanks top hydraulics , appreciated...so as long as its a 'decent' battery I should be ok. )
Best have a look.
S )
broke, engine, not opening, roof
