Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Mid Atlantic
Mid Atlantic
DC DE MD PA VA WV
Old 03-20-2013, 10:48 AM   #1
BMW_Knight
My Ride: STG2 ZHP,E70 X5(DD)
Send a message via ICQ to BMW_Knight Send a message via AIM to BMW_Knight
3.38 Rear Diff & UUC Sway Barbarians
Finally doing my M3 rear subframe and diff this weekend, so I have these items up for sale.
3.38 diff bolt in ready. All flanges already installed for a 330 swap. Sold
UUC Sway bars with adjustable front and rear end links Sold
I also have a 330 rear subframe and drive shaft if you need one make an offer
Thanks to: www.getbmwparts.com www.aatuning.com www.toyotires.com
Eurowerkz Mid-Atlantic Regional Director
Join the Eurowerkz Facebook Fan Site : Click Here
Need your car coded with Euro Options? (Remote Windows up, Corner delete, DRL off, etc.) PM Me
BMW_Knight is offline   Reply With Quote
Old 03-20-2013, 10:59 AM   #2
TrippinBimmer
My Ride: Just Fast!
Welcome to the dark side
Btw rear wheel base will change alittle if you change the whole rear to the m3
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 03-20-2013, 11:25 AM   #3
BMW_Knight
Great, I am already rubbing with 19x9.5 et27 in the rear
Old 03-20-2013, 11:59 AM   #4
JohnBlaze
My Ride: Black Sunshine
I'm pretty sure it's the same width and it's only the M3 rim offset that is the difference between the non-M and M rear axles
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 03-20-2013, 03:32 PM   #5
TrippinBimmer
My Ride: Just Fast!
It changes...Ask me how I know...
Alpine White M3
MaximumPSI Stage4
Old 03-20-2013, 04:44 PM   #6
JohnBlaze
how much does it change?
I'm running the M3 rear end and fitment did not change, that I could tell at least
Old 03-20-2013, 08:58 PM   #7
TrippinBimmer
My Ride: Just Fast!
You running the trailing arms, shafts and all? About 2-3mm on each side...
Alpine White M3
MaximumPSI Stage4
Old 03-20-2013, 09:14 PM   #8
JohnBlaze
Yes I'm running the complete rear axle.
Pretty much all the info I found when I was planning this stated the distance from Hub to Hub is the same on the e46 non-M and e46 M3 rear axles.
The front axles are definitively a different width.
Old 03-21-2013, 07:52 AM   #9
JohnBlaze
OK, so a very knowledgeable e46 fanatic provided me this picture, so according to it, if this is measured from the hub the M3 is more wide.
I do not know for certain this is legit specs
Thanks Stu...
edit,
according to the OP this is not valid and the rear axles are the same diameter from non-M to M.
Old 03-21-2013, 09:29 AM   #10
Navin323i
Europrojektz East
Navin323i's Avatar
My Ride: See Sig
Hey Shane... would the UUC Sway Barbarians fit my E46 or are they different between coupes and sedans? Do you have pics that you can post here?
USA Paralympic Table Tennis Athlete and the 1st in history with Parkinson's Disease and father to these 2 lovely angels below...
BMW Individual Atlantis Metallic Twin Screw S/C'ed 2000 323i
SPONSORED BY: BBS | Modbargains | Toyo Tires | DPE | WheelSTO | Vorsteiner | European Auto Source | Bimmertools | GetBMWParts.com | Race Apeel
Navin323i is offline   Reply With Quote
Old 03-21-2013, 09:37 AM   #11
JohnBlaze
they'll fit your car fine Navin
Old 03-21-2013, 03:08 PM   #12
BMW_Knight
Yes Navin they fit your car. They are still on the car right now, I am removing them this weekend.
Old 03-21-2013, 04:26 PM   #13
Navin323i
Europrojektz East
Navin323i's Avatar
My Ride: See Sig
Cool... so are you selling both the front and rear set or just the front or just the rear? Also would I need to purchase the swaybar bushings from UUC or could I use the existing OEM swaybar bushings I have now?
Old 03-21-2013, 06:42 PM   #14
BMW_Knight
Its front and rear, and it comes with the bushings too.
Old 03-21-2013, 11:25 PM   #15
BCS E46
My Ride: '14 GMC
If Navin doesn't take the sways, I'm in. Can Paypal or just pay in person, your choice.
BCS E46 is offline   Reply With Quote
Old 03-22-2013, 03:47 PM   #16
Navin323i
Europrojektz East
Navin323i's Avatar
My Ride: See Sig
Thanks Shane. I'm definitely interested in purchasing this from you.
How long have you owned these sway bars and once I have these installed, how long before I'd have to replace the bushings given that these are used?
Also, were you able to notice any difference with these swaybars versus the OEM ones? If so then what specifically did you notice in terms of improvement if any?
Thanks,
Navin
Old 03-22-2013, 04:00 PM   #17
BMW_Knight
Navin,
Go on uuc's site and read up on these. It doesn't seem like you have a good understanding of what these are.
Old 03-22-2013, 04:08 PM   #18
Navin323i
Europrojektz East
Navin323i's Avatar
My Ride: See Sig
Navin,
What did I say that gave you that impression? I'm not an idiot and certainly know what sway bars are. I was simply asking for your feedback on how you liked these sway bars and more importantly how long you've owned them.
I've already been on UUC's site by the way... thanks.
Are you ok, Shane? You don't seem like your normal friendly self.
Old 03-22-2013, 04:25 PM   #19
BMW_Knight
Tightens the car, bushings are polyurethane so they have a longer lifespan than the OEM rubber ones.
Of course there is a huge difference.. Car stays flat. Compared to your own ones which are smaller than the zhp ones it will be a huge difference.
Old 03-22-2013, 04:27 PM   #20
Navin323i
Europrojektz East
Navin323i's Avatar
My Ride: See Sig
How long have you owned these swaybars (approximate # of miles with these swaybars installed?)
