E46 Xi Forum
Old 03-20-2013, 12:16 PM   #1
azureus
My Ride: BMW E46 325xi
8x19 et45
8x19 et45
Front - 225/35/19
Rear - 235/35/19
Will it fit on 325xi?
azureus is offline   Reply With Quote
Old 03-20-2013, 02:05 PM   #2
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Yes those wheel specs fall inside the acceptable range on the E46 xi. I'd probably run a squared tire set up vs the staggered set up your proposing.
Old 03-25-2013, 06:39 PM   #3
Lou3viLL3sLuGGa
My Ride: BMW 325 xi
What again are the reasons not to stagger an xi I have square 18x8 now looking at 19 also style 67 want to stagger if I could? Would it make any diff if I spacered the fronts to same offset? All about wheel rev?
Lou3viLL3sLuGGa is offline   Reply With Quote
Old 03-26-2013, 10:20 AM   #4
ECSTuning
ECSTuning's Avatar
My Ride: BMW
You can run staggered wheels on the Xi BUT you need to maintain rolling circumference with proper tire choice to maintain less than a 3% difference.
Old 03-26-2013, 03:16 PM   #5
wdeerfield
wdeerfield's Avatar
My Ride: 2009 E90, 2011 F10
Try to keep it square or to less than 1% difference. With those rim sizes, it doesnt make any sense to go staggered as you will see no benefit from it.
2013 EB 335i xdrive | Msport | Coral | DHP | ZPP | ZCW | ZTP | 400M | Coded | MPerformance Bits | M3 Grills | Painted Reflectors | BMS Exhaust Tips | LED Turn Signals
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
wdeerfield is offline   Reply With Quote
Old 03-26-2013, 03:19 PM   #6
Lou3viLL3sLuGGa
My Ride: BMW 325 xi
Old 03-26-2013, 03:20 PM   #7
Lou3viLL3sLuGGa
My Ride: BMW 325 xi
Right it's not about any real benefit, just the stance and look. Also I have a friend with an M3 and he has the 19" style 67 he'd have sold me in a staggered set, but I ordered a square setoif the 19 though and a 15mm spacer for the rears.
Old 03-26-2013, 06:08 PM   #8
E46er75
My Ride: 323i Vert, 330xi
The wheel size of 18" and the series of "35" wouldn't do any harm on an XI running 225's in the front and 235's in the rear. I think the above replies are being overly cautious. If you run a different series an/or wheel size from front to back then yes, you could have issues depending on the how much of a size difference you go with.
E46er75 is offline   Reply With Quote
Old 03-26-2013, 10:09 PM   #9
Lou3viLL3sLuGGa
My Ride: BMW 325 xi
It is diff wheel size 19x8 are fronts rears 19x9.5
Old 03-27-2013, 12:43 AM   #10
E46er75
Wheel width is irrelevant. Diameter is what matters.
Old 03-27-2013, 07:50 AM   #11
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
Originally Posted by azureus View Post
8x19 et45
Front - 225/35/19
Rear - 235/35/19
you either need 225 35 19 & 255 30 19 or 225/235 all the way around. I recommend 235 to get you some more tire and make the car more comfortable
Royal Elite Club of 6 Speed Tourings - founder
redbull 325is is offline   Reply With Quote
