Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Great Plains & Rocky Mountains
CO IA KS MO MT ND NE SD WY
Old 03-20-2013, 12:59 PM   #1
PerkM3
Account Under Review
My Ride: 2004 SG M3 ESS-550
Denver car inspections
Hey guys, I moved to the northern Colorado a few months ago (Greeley to be specific) and just purchased this car.
http://www.m3forum.net/m3forum/showthread.php?t=436749
My questions are, what are your thoughts on passing the inspection I'll have to do in order to register the car in Colorado. I'm thinking cats for sure but I'm not familiar at all with Colorado inspections.
Any help/advice is greatly appreciated.
PerkM3 is offline   Reply With Quote
Old 03-21-2013, 09:00 AM   #2
docwyte
My Ride: '89 944 Turbo
Does it have cats? If not, put a set on, make sure all the readiness codes are set and you'll be fine. We don't really have inspections here, you can only fail visual if you don't have the emissions stuff there. They do an ODB2 scan for the readiness codes and run the car on a dyno for emissions. Make sure the car isn't too low, otherwise they'll refuse to run it on the dyno and send you packing.
'98 M3, track beast
'06 Porsche Cayenne Turbo S 521hp daily driver
'07 KTM 990 Adventure
docwyte is offline   Reply With Quote
Old 03-21-2013, 09:51 AM   #3
PerkM3
Thanks for the info. The car does not have cats so I figured I'd need those for starters.
Old 03-21-2013, 01:29 PM   #4
cosmos///m3
My Ride: 2005 JB/IR ZCP ///M3
Brad...
If you are coming through KC on your way I can let you use my OEM section 1 if you just want to put it on long enough to pass emissions. LMK
2005 ZCP Schwarz II/Imolarot 6spd ///M3 ||| 1999 Estoril Blau/Estoril Blau ///M Coupe "Clownshoe"
2014 Alpinweiss Uni/Mokka X5 ///M Package (wifey)
cosmos///m3 is offline   Reply With Quote
Old 03-21-2013, 02:31 PM   #5
PerkM3
Originally Posted by cosmos///m3 View Post
Brad...
Wouldn't I need a euro section 1? OEM doesn't have cats in it does it?
Old 03-25-2013, 09:58 AM   #6
docwyte
OEM section 1 doesn't have cats in it. It's debatable whether the car will pass with the Euro cats here, they're placed so far downstream they don't light off very well.
'98 M3, track beast
Old 03-25-2013, 10:07 AM   #7
PerkM3
I'm thinking my best bet would be getting some 400 cell cats welded in an oem section 1 as far upstream as space will allow. Thoughts on that?
Old 03-25-2013, 10:26 AM   #8
docwyte
Yep, or get one of those aftermarket section 1's that come with cats. But you'll want the 400 cell ones at least, the 100 or 200's aren't efficient enough to get past smog. Make sure they have the post cat O2 bungs as well.
'98 M3, track beast
Old 03-25-2013, 11:46 AM   #9
PerkM3
The car came with the supersprint section 1 so I'm trying to find a solution that I can trade for or will be cheaper or similar to what I can get out of the SS section 1. I just bought the car so trying to keep initial costs down for the wifes sake.
Anyone in the CO area looking for a SS section 1 version 2 that bolts up to the oem header and section 2?
