M52TU Question. - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-20-2013, 02:25 PM   #1
RockLee
My Ride: 99 328i. ZSP, ZPP,
Send a message via Yahoo to RockLee
M52TU Question.
I've been searching the threads in the FI section and found some things about the M54 like the issue about the cylinder head rising due to the oem head bolts. Or the threads can pull out of the block if you have ARP head bolts.
Does this affect the M52TU aswell? I personally haven't found any of these issues on the M52TU (At least in this forum) and was simply curious. (Is it because starting with 3 liters is better then starting with 2.5/2.8 so nobody really bothers to build the M52TU's E46's?)
And I personally haven't found any of these issues happening on the regular M52's on the E36. (If anybody can prove me wrong, please do.)
Is the M52TU as prevelent with these issues as the M54? Because this seems to be the biggest reliability issue with boosting non M's than I can find.
1999 328i Sport Package, Premium Package, 5 speed, Alpine white.
RockLee is offline   Reply With Quote
Old 03-20-2013, 05:46 PM   #2
autospeed_01
My Ride: 2000 328Ci
The M52 in the e36 was a cast iron block and that's why this wasn't a huge issue. With the m52tu I'd assume the same weakness (as m54) since the blocks are both aluminum. You'll find more data referring to the M54 simply because that's the commonly boosted engine. A few guys have done 328 m52tu's you just gotta look around for them. Timeserting the block is one way to fight the threads stripping, again if you search there's a pretty hardcore build thread written up by a fellow Canadian.
autospeed_01 is offline   Reply With Quote
Old 03-20-2013, 08:33 PM   #3
summit56
My Ride: 328ci AA stage 1
the only problem I have had was the oil pump nut came off. I have been running AA stage 1 for two years now. 146k miles on the vehicle.
summit56 is offline   Reply With Quote
Old 03-21-2013, 06:55 AM   #4
SweTurbo
Big Pimpin'
My Ride: 323i -98
I ran AA stage 2 on my 323i, only thing was my pistons broke , head never lifted or anything(though the OPN was loose on dissassembly)
Old 03-21-2013, 08:59 AM   #5
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
M52TU are the same as M54s. The main difference is the intake and electronic throttle body. I would expect to see same issues on the M52TU.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptain
BMWCaptain is offline   Reply With Quote
Old 03-21-2013, 10:12 AM   #6
RockLee
(Sigh.) Oh well.
I guess in the future I just have to get another car for me to really get some decent reliable power out of. The Non M E46 platform really isin't for me in terms of a starting point for modding. I don't want an E36 or an M3 of any kind.
I'm looking at japanese in my future. (NO FWD though.)
Old 03-23-2013, 09:09 PM   #7
nleksan
My Ride: 328Ci, 325i, M3 ZCP
Send a message via AIM to nleksan
38K miles with ESS TS2+ (customized by a local BMW Master Mechanic, who's also a friend) with a 6MT from an 06 ZHP, Quaife 3.25:1 LSD, fully built top end (valvetrain), Stg4 FI Cams, Mahle Forged Stock-CR pistons, Carrillo H-Beam Rods, ARP Full Engine kit... Pushing 9psi on 94oct tune, tore engine down after 20k on the kit to inspect and everything still looked brand new. I have photos posted on BITOG somewhere...
(Temporary Sig)
- DPE - Volk - BBS - OE CSL - JRZ Race 4Way -
- M-Tech II - RE - AP Radi-CAL -
- Hotchkis - AFE - AKG - KW CS 4way -
- TMS - OS Giken - SS V1 - Vorsteiner - Recaro - Focal - JL - MORE! -
GARAGE:
-00 328Ci Topaz 6MT ZSP/ZPP/HID (Street) ESS TSE2+ 2980lb
-01 325i TiAg 5MT/ZSP/ZCW (Street) Track Susp/Brk/Whl 3102lb
-06 M3 AW/IR 6MT/ZCP/HID (Dual-purpose) NA Fully-Built 2810lb
nleksan is offline   Reply With Quote
Old 11-24-2013, 05:27 PM   #8
RockLee
Bump.
Is cryo treating the engine block a good idea to help the threads from stripping? Has anybody done it?
Old 11-24-2013, 06:06 PM   #9
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Originally Posted by RockLee View Post
Bump.
Part of cryo treatment is heat treatment post-cold-process. Unfortunately, the aluminum used in the M52TU and M54 block doesn't like being heated above 260 degrees which is required for this process.
So no...it's not a good idea.
Old 11-24-2013, 06:34 PM   #10
RockLee
Is Timeserting the block the only way to help this? What Psi does this usually occur? I've heard that its over 10 psi. Is this true? What do you think the 'buffer zone' is after Timeserting the block?
This engine has also been once at 250 degrees before the expansion tank popped. Is my block Junk?
Old 11-24-2013, 09:21 PM   #11
Hobbit382
My Ride: 99-328i 00-323i
The m52tu actaully seem to be a lot worse than the m54s. Not sure why but I've just seen 10 times more m52tu with headbolts stripped than m54s. As far as boost goes timesert with 11mm studs should go a long way as long as the tune is good, and you don't overheat it. Would recommend getting a lower temp Tstat and replacing your etank regularly.
Hobbit382 is offline   Reply With Quote
Old 11-25-2013, 03:21 PM   #12
willsbma
My Ride: 99 323i
Timesert the block and do arp head studs.
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
Old 11-25-2013, 04:10 PM   #13
RockLee
I'd assume that no metal would really like to be at a high temp for a sustained time. BUT.... won't the metal be 'stronger' after the cryo treatment? After its been through really low temps instead of just cooling it down to 'room temp?'
Am I making sense? I'm going to ask a couple of shops that do the process to see if this is a good idea. Gotta start somewhere i guess.
Old 11-26-2013, 12:41 PM   #14
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
I ran my TU for 100k+ miles peaking 14psi with no issues, on stock head bolts. If you have a solid tune, and never let it get hot, you'll be fine.
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 11-26-2013, 12:45 PM   #15
RockLee
Very Good to know. I assume you DON'T have an oil cooler? Does this engine really need one?
Old 11-26-2013, 12:54 PM   #16
Activ3
Water temps are more important to watch when worrying about lifting the head. I never had an oil cooler, and just changed my radiator, expansion tank, and coolant hoses once a year as preventative maintenance.
Old 11-26-2013, 01:46 PM   #17
Lercs
My Ride: 00 328i, 00 323it
At 8legs Racing, we have had the head lift on non-boosted cars. We have had it happen with studs in the heads and with time-serts.
The biggest thing to worry about is the overheating. Don't start with a block that has ever seen high heat.
Follow 8legsRacing on twitter and Facebook
@8legsracing
www.facebook.com/8legsracing
www.8legsracing.com
Lercs is offline   Reply With Quote
Old 11-26-2013, 01:58 PM   #18
Lercs
and like mentioned above, the block is basically the same between the M54 and the M52TU. (depending on year, there are a few small differences, but not ones that would affect the head lifting problems)
@8legsracing
www.8legsracing.com
Old 11-26-2013, 02:54 PM   #19
RockLee
The engine temp has been up to 250 degrees once, before the expansion tank popped and I shut off the engine. The engine runs fine and doesn't consume any oil or coolant.
Old 11-30-2013, 02:21 PM   #20
RockLee
I'm just debating getting a supercharger or Just swapping a S54 engine in. This car has a lot of sentimental value to just 'sell and buy an M3'.
However the S54 costs a lot of money to swap in and the aluminum block on my engine has a risk of being ****. I don't wan't to dump a lot of money into this engine only to have the block be crap and then have to find another block and probably have this happen again. Hell, I'm tempted to see if I can swap an S52 in here.
But then again, Like in Activ3's case. This might not happen. But that risk is....just bugging me.
I know you have to pay to play. But nobody is going to deny that it sucks having an engine blow op on you.
Man. Idk what to do.
