Sponsored by BimmerWorld
Old 03-20-2013, 07:17 PM   #1
hitmanre
My Ride: 2000 BMW 328i
Shock questions
S226A SPORTLICHE FAHRWERKSABSTIMMUNG Sports suspension settings
On BMWVIN i see that i have sports suspension and many times when im looking for shocks i see Excl w/ OE Sport Suspension. What shocks can I get??
hitmanre is offline   Reply With Quote
Old 03-20-2013, 07:32 PM   #2
Dave1027
My Ride: '06 IR zhp coupe
The sports suspension is lower with less travel. You need to use shocks and struts that are designed for that. Go with Koni or Bilstein.
Old 03-20-2013, 08:06 PM   #3
hitmanre
will this work?
http://www.amazon.com/gp/product/B00..._email_1p_2_ti
Old 03-20-2013, 08:27 PM   #4
lcoleman
My Ride: '79 Massey Ferguson
All e46 (edit: non-M) dampers should be interchangeable. The springs are what affects ride height, so the dampers should be matched to the springs. Stock sport springs are not aggressive.
Monroe is OK, but I'd pony up for some more reputable ones like Bilstein, Koni, or Sachs.
Old 03-20-2013, 08:42 PM   #5
hitmanre
i read here that since i have sport springs i need shocks that will match
http://www.bimmerfest.com/forums/sho...d.php?t=214584
Old 03-20-2013, 08:49 PM   #6
Gus330vrum
My Ride: 330ci
Like mention above^
Bilstein sport & koni adjustables on sale $700 a set of 4.
( I would go koni adjustable & get lifetime alignment) you can lower it or make softer ride + alignment anytime.
Sachs is factory & fails at 50k lol.
Avoid it. Maybe ..
Now, KW is coilover at $1,200+
Gus330vrum is offline   Reply With Quote
Old 03-20-2013, 08:52 PM   #7
hitmanre
i dont have that much for konis, but i need something in the meantime, I can get a whole set of monroes for 200$ shipped on amazon, so im wondering if it will work or no?
Old 03-20-2013, 08:58 PM   #8
silyb0y
My Ride: E46 330
Check the Bilstein product catalog (B4 -> OEM replacement shocks). You will see that Bilstein only offers ONE rear shock absorber for all non M3 models. They are all the same. Bilstein does offer TWO different front shock absorbers. One is for the M2 suspension package ("stiffer"). The other one is for all "regular" suspenions which includes your "sportliche Fahrwerksabstimmung".
Why is that so? The "sportliche Fahrwerksabstimmung" only means -> lower springs. The springs lower the car by only one inch. You dont need special shock absorbers for that...
silyb0y is offline   Reply With Quote
Old 03-20-2013, 08:58 PM   #9
Gus330vrum
My Ride: 330ci
You will soon have to replace it again, + pay for another alignment.
Monroe poor handling/durability? Ive read on other forum people using Monroe but the price speaks for it self in terms of quality.
from personal experience, save up money and drive the car crappy for now until you buy the koni or bilstein set too replace it all at once.
Old 03-20-2013, 09:06 PM   #10
hitmanre
Wheres the cheapest place to get konis?
Old 03-20-2013, 09:21 PM   #11
Gus330vrum
My Ride: 330ci
http://www.tirerack.com/suspension/S...3&autoModClar=
save the money & buy the set.
Check other suspension parts also like tie rod,control arm+bushing, rear shock mount( google:roguee shock mount)
Old 03-20-2013, 09:53 PM   #12
beckpiece
My Ride: '03 ZHP & '16 STi
http://www.tirerack.com/suspension/s...3&autoModClar=
Get the KONI STR.t shocks.
Awesome quality for a stock setup a d they're on sale now.
03 TiAg 330i ZHP
beckpiece is offline   Reply With Quote
Old 03-20-2013, 10:58 PM   #13
laconic
My Ride: 2001 325i
Sports shocks/struts & springs on a standard 325i
Friends, I have a 2001 325i with standard suspension. Can I install the springs, struts and shocks that go with the Sports Package? Is there anything else in the package that I am missing? Will it work? Thanks.
laconic is offline   Reply With Quote
Old 03-20-2013, 11:01 PM   #14
SeanC
My Ride: 330i
Originally Posted by mrlatexxx View Post
Like mention above^
Avoid it. Maybe ..
Koni's are rebound adjustable. Not height. What are you talking about?
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Alpine WhiteTanSand High Gloss e46 330i SlickTop/5MT - Sold
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
SeanC is offline   Reply With Quote
Old 03-20-2013, 11:02 PM   #15
SeanC
My Ride: 330i
No need to replace the springs unless you want to go lower. Just get some good quality shocks+struts and call it a day.
Old 03-20-2013, 11:14 PM   #16
laconic
My Ride: 2001 325i
Thanks, Sean. The car has 108k, so I thought replacing the springs might be a good idea. So, if I understand you correctly, I can put shocks/struts--Sachs or Bilstein HD or Koni Strt--that fit the Sports Package, and it will work without changing springs. Or...if I do put springs in, I can put Sports Package springs. Right?
Old 03-20-2013, 11:30 PM   #17
SeanC
My Ride: 330i
You may combine sport package springs or your current ones with any of the dampers you listed. I would however recommend spending extra for Koni Yellows instead of STRTs. Bilstein HD's will be a little rough for daily driving. Springs should be good at that mileage, unless they are broken (you would have noticed). I replaced my dampers at 150k miles and kept the factory springs.
Old 03-20-2013, 11:34 PM   #18
laconic
My Ride: 2001 325i
what's the story on the STRT's; do you not like the ride, or will they not
last long enough? I appreciate your comment that the HD's might ride too hard. Thanks.
Old 03-20-2013, 11:38 PM   #19
SeanC
My Ride: 330i
Lasting long is a moot point since they should come with a lifetime warranty from Koni. Not the perfect fit IMO for a sports sedan. Too soft, similar to a non-sport suspension ride.
Old 03-21-2013, 12:00 AM   #20
laconic
My Ride: 2001 325i
Smile
SeanC; I am grateful for your time and perspective, and I appreciate your
knowledge. Any way to be able to email you? Tnanks either way.
