Old 03-20-2013, 10:07 PM   #1
Dtmnuka
My Ride: 2004 325i
o2 sensor CEL?
Since I've had my 04 325i ive been getting 13-14mpg!! Ive done spark plugs and everything I read tells me to replace my o2 sensors before the cat but if they were bad wouldnt my check engine light be on? I just dont want to replace them and continue to get this awful gas mileage.
Dtmnuka is offline   Reply With Quote
Old 03-20-2013, 10:36 PM   #2
HakenTT
My Ride: 323i with S54
If the 02 sensors were bad I am positive you would have check engine light for them.
If your MPG is poor and you have no fault codes. then it may be posible that thermostat is stuck open and it takes long time for the engine to get into operating temperature
HakenTT is offline   Reply With Quote
Old 03-21-2013, 03:43 AM   #3
Dtmnuka
My Ride: 2004 325i
Okay ill check that asap. It being stuck open can effect the mileage that severely huh? I had no idea. Thanks for the suggestions.
