Old 03-21-2013, 12:00 PM   #1
fastsoup
My Ride: 05 M3 Vert/11 X3 M
DRL wire tap
Hi Guys,
In Canada we need to run our HB at a lower wattage while the headlights are off. Once the low beams are turned on, DRL's turn off. I am currently running my halos to the ECU so they are when the car is on, but I want them to turn off once my low beams turn on. Is there a way to do this...does anyone know where the DRL wire is to piggyback?
P.S...I have disabled my DRL's so I wouldn't get the yellow bulb look...will I need to turn them back on in order for this entire thing to work, or does disabling them just turn them off at the bulb and not the entire wiring assembly?
fastsoup is offline   Reply With Quote
Old 03-21-2013, 01:51 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
You can't unless you put in a switch to control the angel eyes.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 03-21-2013, 04:18 PM   #3
DOT.
My Ride: '04 ZHP Sedan
You'd need to wire up a n/c relay and probably use the low beam to trigger it to turn off...
DOT. is offline   Reply With Quote
Old 03-23-2013, 03:27 PM   #4
sillieidiot
My Ride: '06 AW 330ci
^ pretty much what he said. need a new relay. the easiest way would be to turn your DRLs back on and tap it to the high beam wire
