Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Great Lakes
Great Lakes
IL IN MI MN OH WI
Old 03-21-2013, 06:33 PM   #1
Passnu2
My Ride: Sport Wagon
Smile Wheel Boring Provider around St Charles
Anyone have someone they can recommend close to the St Charles area? Looking to help a friend out and traveling too far won't be an option.
Elgin, Geneva, Batavia, Aurora would all probably work or I could help drop off and pick up in these areas.
Thank you
2000 323iT - 158k
Recent Maintenance: Spark Plugs/CCV/Expansion Tank/Radiator/Thermostat/Both Intake Boots/Air Filter/Cabin Filter/Valve Cover Gasket/Control Arm Bushings/All Pulleys/Hatch Shocks/Vanos Oil Line/Fuel Pump/Fuel Pressure Regulator/Rear Rotors & Pads/Belts/Water Hoses/Front End Links/Front Sway Bar Bushings/Alternator/Power Steering Hoses/Power Steering Reservoir.
Passnu2 is offline   Reply With Quote
