E46 Xi Forum
Old 03-21-2013, 08:06 PM   #1
e46yayo
My Ride: 02 330xi
PLEASE HELP !!! e46 electrical problems !!!
PLEASE HELP!! e46 electrical problems!!
So I have more than a few electrical problems I need help with. my mechanic says he cant do anything and last thing id want to do is go to the dealer so this is my only option till something worst happens
1. Starting issues ( when I start it up I always keep it on position 2 until the beeping goes off or close and one day it didnt want to turn over it just keeps trying like its a fuel or spark problem. So I found out if I just turn it from the postion right when you put it in it starts everytime)
2. Dash lights stop working on my signals and highbeam but*work*externally
3. Curb finder(passenger side mirror tilt on reverse) doesnt work at all but manually does
4. Trunk buttons stop working have to use my*keys
5. Sunroof tweaks on occasion
e46yayo is offline   Reply With Quote
Old 03-21-2013, 08:51 PM   #2
Kubica
My Ride: 2003 325xi
1) sounds like a key issue. Do they both do this? Why are you sitting there listening to the beeps anyway?
2) remove angel eyes
3) toggle the left right switch to the middle
4) use the key to turn the lock on the trunk 90 degrees.
5) search for DIY on the sunroof clips (or remove the shade) and grease the tracks.
Old 03-21-2013, 10:40 PM   #3
e46yayo
My Ride: 02 330xi
I usually wait for the beeping thinking its best. but anyway I lost my key about a year ago and got a replacment from the dealer
I dont have any angel eyes
And ive tried the switch
Ive never put the key in the trunk but ill check.
Also my doors stop locking automatically when driving past 5mph
Old 03-22-2013, 10:11 AM   #4
SamDoe1
My Ride: 4cyl of fury
1.) Just start it up every time? I'm not even sure what the beeps are for anyway other than a buckle up reminder.
2.) Does it do this intermittently or all the time?
3.) Do you have auto or manual? If manual, your reverse sensing switch is toast, replace it. It's cheap.
Use Kubica's advice for the rest.
Edit to add: My doors never lock when driving at any speed unless I push the button.
Old 03-22-2013, 07:29 PM   #5
pppham
My Ride: 740il S500 330CiC
E46yayo, if your key start and won't crank could be alot of things such as fuel pump, sparks, or coils or could be as easy to change as Campshaft sensor. Now, if it won't start or crank (aka see all dash lights ) this one could be the classic problem for the Crank Sensor. Or could be your EWS module could not recognize/link your key to DME. Best way for you to find out is go toAdvance or any auto parts to get the codes read or you can purchase the PAsoft cable and software for less than $40 and diagnose yourself. About the trunk and the mirror (dunno all the details) you can easily try to resync your key with the GM5. There are so many threads on this forum just search for it. Just remember to point your key Fob, non vert the antenna is on the back and vert is inside the rear view mirror (just point it to the clown nose). Hope this will help.
PS if you have manual, you can use PASoft to deactivate the clutch to start your car.
pppham is offline   Reply With Quote
Old 03-22-2013, 10:10 PM   #6
e46yayo
My Ride: 02 330xi
I cant read any codes my check engine light isnt on
Yea I got auto
Old 03-22-2013, 11:30 PM   #7
Kubica
My Ride: 2003 325xi
Maybe you have a valet key.
Old 03-24-2013, 09:35 AM   #8
pppham
e46yayo, any good news? Hope you can share with us. To all of the great BMW warriors out there (to name a few - jfoj, AC 2007, NumbaOneNewb, Kubica etc.....) - my car have the following problems:
1. Two key fobs will not work lock/unlock remotely for my 01 330 vert (have try everything to resync from all forums/suggestions. Have tried hard boot. Have disconnected/reconnected the battery after 24hrs). Have checked fuses... Keys start car... working manually for lock/unlock...trunk button or key is working fine....Gas cover plate worked accordingly for vert...glove box is working fine.
2. What else is not working -- footwell and dome light and central locking switch (Central locking switch could be based on the current status of central locking system?)
Any help is greatly appreciated
Old 03-24-2013, 10:04 AM   #9
e46yayo
My Ride: 02 330xi
My doors stop lockin when moving
My trunk buttons dont work in the car
All my interior lights work besides my signal and high beam and fog lights my fog kight dont work at all inside or out
