E46 Xi Forum
Old 03-21-2013, 08:56 PM   #1
djbradle
My Ride: 2002 325 xit
Crazy vibration while idling in D or R
I've been troubleshooting this issue for a long time now and have come nowhere to fixing it. I've changed engine mounts and all suspension components except the front strut assemblies( car's in garage now on jacks and I'm finishing up the Bilstein HD's tomorrow morn). Done half shafts twice. I still get a little vibration at around 60 mph. Axles are reman's so they could be causing that. Tie rods, inner/outer are done. I haven't changed any steering column components yet like the u joints or upper column.
The vibration is everywhere; dash, seats, steering wheel especially when I turn it left to right . . . all the while when I'm idling. As soon as I start to drive or reverse it disappears.
It's gotta be something drive-line related, no?
Transfer case bushing?
Transmission mounts?
Differential mounts?
This has got me stumped.
djbradle is offline   Reply With Quote
Old 03-21-2013, 09:07 PM   #2
jmo69
My Ride: 03 325xi 98 328is
I've got an occasional vibration too and my research only came up with cleaning the MAF, didn't do it yet because mine looked to be clean.
HERSHIS
2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
Old 03-21-2013, 09:09 PM   #3
djbradle
I cleaned the MAF too. Didn't change a thing. And it looked spotless. 170K miles now. First time the front struts have been done too. I couldn't believe they lasted so long.
Old 03-21-2013, 09:18 PM   #4
Kubica
My Ride: 2003 325xi
Didn't someone have a similar issue caused by a bad torque converter?
Or maybe a harmonic balancer issue...they go occasionally.
Old 03-21-2013, 09:27 PM   #5
djbradle
I had posted something awhile back about both being a possible issue. Vibrations in my book mean something is loose. I'm not even sure where the harmonic balancer is (around the water pump?) . . . Maybe the Vibration damper (11231438995) otherwise known as the crankshaft pulley? It does cover my build date of 10/01.
Old 03-21-2013, 09:36 PM   #6
djbradle
On a side note : Mmmmm . . . I'm enjoying a Biere De Garde I brewed back in September aged on raspberries.
Old 03-21-2013, 09:48 PM   #7
djbradle
So it appears that the harmonic balancer is attached to the crankshaft pulley. Is this just rubber around steel? I would fain never pay for a new engine because of this. Maybe if it's removed the vibrations would increase. I couldn't imagine the labor involved. . . .
Old 03-22-2013, 10:19 AM   #8
SamDoe1
My Ride: 4cyl of fury
Check idle control valve, O2 sensors, fuel pump, fuel filter and intake boots for vacuum leaks. You have a rough idle off throttle where the engine is defaulting to a preset fuel map. Somewhere, it's not getting enough gas and you are bordering on a lean condition code. It's just over the horizon...
I wouldn't bother with the harmonic balancer, it's likely not the problem. I had this issue with both my old Passat and my current Expedition, the issue was one of the ones I told you above.
Old 03-22-2013, 02:22 PM   #9
mach460
My Ride: 04 325 xi
Broken fan blade?
had that on an older t-bird,the tip of one of the blades cracked off vibration through the hole car.
mach460 is offline   Reply With Quote
Old 03-22-2013, 03:12 PM   #10
djbradle
Fans good. Sam, fuel filter is newer. I'll test the others. 02 sensors have never been done. No vacuum leaks in any of the secondary air system, intake system, or crankcase ventilator system as all were just done not 1 week ago and this problem has been long standing. Fuel pump . . .don't know how to check that.
Old 03-22-2013, 03:14 PM   #11
djbradle
No cel's on the dash or anything through the peake reader except one of my accelerator pedal sensors has been bad for awhile.
Old 03-22-2013, 04:19 PM   #12
SamDoe1
Change O2 sensors, clean the MAF, clean the intake air temp sensor, replace IAT sensor o-ring, clean ICV, replace DISA o-ring.
That should fix your troubles.
Old 03-23-2013, 07:49 AM   #13
My white xi
My Ride: 2004 330xi
So over the weekend is got this code p0014 and p0015 ..
i got the car inside and check every thing cause i did a VCG last week..every thing was OK..
i tested the solenoid and the 2 of them are working but the exault one was slow to click click.so i cleaned them out and the car run just perfect..the car sit inside all winter and the solenoid must got stuck..remember that the idle was running a bit high before i got the code..in my case here i didn't get the lost of power.the car was just poling fine..
My white xi is offline   Reply With Quote
Old 03-25-2013, 10:23 PM   #14
Bmw-life
My Ride: 325xi 2003
i have that same vibrations in my car when it is in drive then when i put it in N it goes away?
Bmw-life is offline   Reply With Quote
Old 03-26-2013, 01:29 AM   #15
E46er75
My Ride: 323i Vert, 330xi
I have started threads about this problem and replied to threads regarding this issue. I myself have replaced ever thing possible and mine still is a 3000 lb vibrator in cold weather... wait for the weather to warm up and it will go away, mine does this every winter..
Nobody has successfully fixed this issue and it is a known flaw with the XI's. I'm to the point of just wanted to sell mine then deal it it anymore..
Sorry wish I had an answer for you.
E46er75 is offline   Reply With Quote
Old 03-27-2013, 06:10 PM   #16
djbradle
Would be nice E46er75 but mine is not temp biased . . all year long for me.
Old 03-27-2013, 06:12 PM   #17
jacob220
My Ride: 2003 325i 5spd
Engine mounts
jacob220 is offline   Reply With Quote
Old 03-27-2013, 06:12 PM   #18
djbradle
Originally Posted by SamDoe1 View Post
Change O2 sensors (Will Do), clean the MAF(Been done), clean the intake air temp sensor(Where's that?), replace IAT(What's this?) sensor o-ring, clean ICV(Need too), replace DISA o-ring(Will do).
Cool.
Old 03-27-2013, 06:14 PM   #19
djbradle
Originally Posted by jacob220 View Post
Engine mounts
Already done.
Old 03-27-2013, 06:19 PM   #20
djbradle
Do you mean the Intake air temp sensor o-ring? 13621739510 . . . no part number for the DISA o-ring that I can find.
