E46 Xi Forum
Old 04-05-2013, 09:47 PM   #41
E46er75
My Ride: 323i Vert, 330xi
Originally Posted by djbradle View Post
E46er75- Have you every replaced this?
I have not tried this fix. Although I did mention this myself on another thread, many people shot it down and kept me pointed in the intake,leak and emission areas. If I wasnt so fed up chasing this issue around I would most likely tackle the mounts next. But as of lately, I have grown frustrated and frankly have given up on it.
If you do attempt these fixes please keep the thread updated.
E46er75 is offline   Reply With Quote
Old 04-07-2013, 07:08 AM   #42
latitude39
My Ride: 2002 325xi (163k)
How about the Center Support Bearing? Has any Xi'er had this as the culprit?
The driveshaft is stationary in the condition you've described--in D or R, idling, not moving. I doubt the CSB could vibrate in that case.
latitude39 is offline   Reply With Quote
Old 04-07-2013, 07:37 AM   #43
latitude39
and the transfer case bushing.
^This is what I'm thinking at this point. Once in D or R the transfer case already is taking the power from the tranny. Holding the brake while a T-case bushing is bad could be the very cause when idling.
Have you inspected the Tcase bushing for obvious wear?
If this vibration happens only when in D or R, idling, foot on brake, then you may be able to make it happen on a lift or 4 jack stands, in which case the Tcase bushing could be observed while the vibration is happening.
Old 04-07-2013, 07:50 AM   #44
latitude39
Originally Posted by E46er75 View Post
BTW, the temp hit 55 today and guess who's car starting to idle better...
Hmmmm....170k miles on original O2 sensors. And now the vibration is reduced because of warmer weather. Service interval is 100k on these items.
If the transfer case bushing is ruled out then my next *GUESS* would be to replace at least the 2 pre-cat O2 sensors, if not all 4. It's my understanding that the pre-cat sensors affect performance more than post-cat O2 sensors.
Old 04-07-2013, 12:39 PM   #45
djbradle
My Ride: 2002 325 xit
Yup 170k. Second battery since around 40k. Original o2 sensors pre and post. The 02 sensors are pricey so I'll do those as the last possible fix. Just finished upgrading the suspension to almost new condition (man, it feels good again). I'll go check the IAT, replace the lower t-boot( have one on hand), and clean the Icv right now.
djbradle is offline   Reply With Quote
Old 04-07-2013, 01:09 PM   #46
SamDoe1
My Ride: 4cyl of fury
Your fuel trims are so far off right now it's not even funny. Replacing the pre-cat sensors will likely get you an extra 3-5mpg or more at this point, not to mention better performance and throttle response. I would replace those since they are 70k miles past due per the factory maintenance schedule, not the obsessive E46F one.
When you go to "check" your IAT sensor, spray it with MAF cleaner to get all the gunk off of it. Don't touch the sensor itself as it is very delicate. Clean your MAF while you're at it, it'll be out of the car anyway.
Old 04-07-2013, 03:02 PM   #47
djbradle
Got to your post late but I cleaned the MAF for the second time in 8 months and got to the ICV to check that. It was pretty frozen so I sprayed it with MAF cleaner a couple times to let the valve spin freely and it did move nice and smooth after a spray or two or seven. I replaced the lower throttle boot too just because I had an extra. It was in good shape. I broke the F connector of course and just replaced that temporarily with a y connector from Autozone. I'll get to the IAT soon enough but in the meantime I'll buy the pre and post O2 sensors to install as well.
All in all there wasn't much difference at all in start up, idle, D, and R. Maybe some placebo involved, maybe not. I'll get to the other stuff next w/e. Thanks for the response SamDoe1
Old 04-07-2013, 06:56 PM   #48
SamDoe1
^ MAF cleaner isn't going to do jack to clean out your ICV. You need to hit it with brake cleaner to get that bastard back to good working order. The way I did it was hold it so that the inlet is pointing up and just spray until it's roughly 1/3 of the way full of brake cleaner. Then shake it around in there to get it as clean as you can get it and then dump out the cleaner. Do this two more times to get it as much out of it as possible and then spray some WD40 in there to lube it up, again dump out the excess. Then leave it to dry for 8 hours MINIMUM. If you don't let it completely dry, you can backfire your intake and that won't be a cheap fix.
This all reminds me that I need to clean mine up again this spring...
Old 04-07-2013, 10:50 PM   #49
Kubica
My Ride: 2003 325xi
Only need to buy PRE cat o2 sensors.
Old 04-08-2013, 09:55 AM   #50
djbradle
Cool because those are easy.
Old 04-08-2013, 09:58 AM   #51
djbradle
Oh well. It had a little sludge still on there but it did move very freely so I'll do the brake cleaner/WD-40 the next go around. When I do the steering column that will be a good time to do it.
Old 04-09-2013, 01:15 AM   #52
Iggy27
My Ride: 2003 330xi
My xi vibrates when I pull up at a stop light at a complete stop. But if I let the car creep forward just a little the vibrating goes away but will come back when the car is at a full stand still. But only when Iam in D in if I go into N so shaking at a stand still. What I going on??
Iggy27 is offline   Reply With Quote
Old 04-09-2013, 06:54 AM   #53
jonnie325xi
My Ride: 2004 325 XI
Mine does exactly the same thing.
jonnie325xi is offline   Reply With Quote
Old 04-09-2013, 05:26 PM   #54
djbradle
Maybe something to do with the output shaft, torque converter engaging, front input shaft from the transfer case to the front axle before engaging . . .only seems to affect xi's. If someone has changed their transfer case bushing and can attest to this as a solution out there that would be grand.
Old 04-09-2013, 06:19 PM   #55
mmaldin
My Ride: '04 325xit '94 325i
I have started threads about this problem and replied to threads regarding this issue. I myself have replaced ever thing possible and mine still is a 3000 lb vibrator in cold weather... wait for the weather to warm up and it will go away, mine does this every winter..
Nobody has successfully fixed this issue and it is a known flaw with the XI's. I'm to the point of just wanted to sell mine then deal it it anymore..
Sorry wish I had an answer for you.
Mine does it in the winter too. Always hoping someone will post a solution.
Sent from my Nexus 7 using Bimmer App
mmaldin is offline   Reply With Quote
Old 04-09-2013, 08:59 PM   #56
latitude39
Define "vibrate." My 325xi ( automatic, 131k miles) had a "buzzing" sensation especially in the steering wheel when stopped at lights. It felt OK to me but my wife, the previous operator of this car, mentioned it. I replaced the motor mounts, which showed a lot of "flattening." The "buzz" went away and the car now idles perfectly again.
Are you guys talking about a loping idle, with the engine about to stall...or is this more like my steering wheel buzzing sensation? Do the RPMs remain steady?
Old 04-09-2013, 10:19 PM   #57
Iggy27
My Ride: 2003 330xi
My whole car vibrates but it's not like a huge amount it's just enough to annoy me. And when the ac is on it shakes a little bit harder
Old 04-14-2013, 10:51 PM   #58
latitude39
ICV, MAF, pre-cat O2 sensors, torn boot at throttle body (vacuum leak). Have you done any of these? How many miles?
Old 04-14-2013, 10:54 PM   #59
Iggy27
My Ride: 2003 330xi
What do you mean by do? I've cleaned my MAF and ICV no vaccine leaks. But I have some little tears at the lower intake boot that go into the ICV and the car has 140 000 miles
Old 04-14-2013, 10:58 PM   #60
E46er75
FYI, bought my XI with 60k now has 85k and this issues has been present ever since I took ownership..
