Engine vibration question from novice - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-22-2013, 05:11 AM   #1
garen45
My Ride: 2003 330ci
Hey guys I have a question, I've been searching all night and can't find a solid answer...
I have an 03 330ci 97,000 miles and when the car is in park there is no vibration but when i put the car in reverse or drive there is a slight vibration when completely stopped (none when driving).
The spark plugs haven't ever been changed and I was wondering if this could be the issue but then I thought if it was the spark plugs wouldn't it vibrate even in park?
I had the rear main seal of the engine changed at about 70,000 miles or so, and I would assume they changed the transmission mounts at that time and also they had at that time told me the engine mount or mountS where bad and had to be changed so I'm ruling the mounts out for now.
Can someone let me know about the spark plug and if bad spark plugs only cause vibration when in drive or reverse or they should vibrate while in park also.
garen45 is offline   Reply With Quote
Old 03-22-2013, 07:02 AM   #2
lcoleman
My Ride: '79 Massey Ferguson
Don't rule out mounts, they're probably the cause. They wouldn't have changed them with a rear main.
Misfires are unlikely.
Old 03-25-2013, 10:30 AM   #3
NumbaOneNewb
My Ride: 2003 330CI Silver
Its your motor mounts
Sent from my SPH-L710 using Bimmer App
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 03-25-2013, 10:31 AM   #4
NumbaOneNewb
Does it vibrate in neutral? Does it feel like the idling stables off when placing it into neutral? If so, motor mounts
Old 03-25-2013, 05:20 PM   #5
garen45
My Ride: 2003 330ci
Yea it stables in neutral, damn ok I will change them, should I also change the transmission mounts or no?
and how many motor mounts are there?
Old 03-25-2013, 05:32 PM   #6
lcoleman
There are two. It's impossible to know if you need trans mounts without looking at them, and even then they can look OK and not be. There are two of those as well.
Old 03-25-2013, 05:34 PM   #7
garen45
My Ride: 2003 330ci
ok sounds good thank you very much.
Old 03-25-2013, 06:31 PM   #8
NumbaOneNewb
I'm dealing with this issue myself. when I gather up some money and time I'll need to do this also. if motor mounts are bad then I would expect tranny mounts are also or not far behind
Old 03-25-2013, 06:34 PM   #9
NumbaOneNewb
also if you prefer a vibration free idle and smoother quieter car, look for OEM or non stiff mounts. installing stiff mounts may increase performance in some way but you will sacrifice comfort and your sanity.
Old 03-26-2013, 04:12 AM   #10
garen45
My Ride: 2003 330ci
yea i'm just going to get the oem mounts as soon as I get some money saved up.
