Old 03-24-2013, 07:08 AM   #1
Diabolu$
My Ride: 330 ci supercharged
Question FI Most Extreme camshafts
Im looing for Most Extreme camshafts to put on my supercharged m54b30.
I dont want to get low tq and hp untill 6000RPM, need to get the best in all respects.
The engine will work 7500RPM redline.
I need to know all technical info (angles, elevations etc).
The camshafts will be used with hard pushers.
so if you have an info about spring i will be glad to hear also.
May be i will use another valves, but not planning to spend too much $ for it.
I have opportunity to make custom camshafts so i belive to make it the best.
Thank you very
Diabolu$ is offline   Reply With Quote
Old 03-24-2013, 10:04 AM   #2
Twin_Turbo_S54
My Ride: M3
custom is the way to go.
I would suggest to rev 8500 rpm and get custom camshafts / solid lifters / proper springs.
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 03-24-2013, 11:17 AM   #3
TxZHP04
My Ride: ESS TS2+ ZHP
I would highly recommend against an 8500 rpm or even a 7500 rpm rev limit for an M54B30. It's going to take a lot more than solid lifters and upgraded valve springs to support those kinds of engine speeds - it's the bottom end you really need to worry about. With enough money anything is possible but, IMHO, the M54B30 is simply a really poor starting point if you're wanting to build something to run high rpm reliably.
Old 03-24-2013, 11:49 AM   #4
Diabolu$
I need to get technical information, what exactly I must to do with camshafts.?
Old 04-02-2013, 01:05 AM   #5
braaang
My Ride: E46 M3
big duration + lift. tune vanos (or dial in cams) to give large lope separation angle..
wouldnt worry so much about the cams as headwork + manifold.
next Q: what do you plan to do with this poor thing with a 1500 rpm operating range?
braaang is offline   Reply With Quote
Old 04-02-2013, 08:10 AM   #6
FragNasty
My Ride: Car
I think you misunderstood. low torque is at something like 2K RPM, max power at 6K, redline at 7.x K rpm.
He will see something like a 4K rpm peak operating window.
If anyone has definitive information here, please post. Cam configuration are almost a black art. Very dependent on performance goals.
Lobe separation is a tune issue here; the engine has vanos.
Is it correct to say that more lift duration is normally more a requisite for high RPM applications? Maybe Vanos can compensate by reducing the lobe overlap (increasing Lobe separation). Old hot-rods with round lobes often sound bubbly and don't idle well because of too much lobe overlap meant for higher RPM operation.
Is it true that there is an optimum lift value that is roughly based on valve size, above which you don't see performance gains? If a project insists on more lift, it basically puts more strain, wear, and tear on the valvetrain than is needed.
An agressive cam profile is defined as how fast the profile will cause the valves to open and close, it's determined by how "steep" the profile gets. Some agressive cams even have a slight concavity at some moment in the lobe profile. The problem is that agressive profile exacerbates the problem of valve float; you need stiffer springs and/or a more rounded peak (more duration).
Obviously lighter valves and retainers are desirable since less intertial mass means valve springs can be softer.
The OP should call a shop that works with custom cams, the details and considerations in topic obviously can go way beyond wrenching.
FragNasty is offline   Reply With Quote
Old 04-02-2013, 08:19 AM   #7
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Werd. Not to mention the head work involved. Easily a $10k engine unless you want it to fall apart. My biggest concern is finding a tuner especially for an MS45 DME.
But what's the point? More power? If you wanna do it half a$$ed just turn up the boost.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 04-02-2013, 11:00 AM   #8
MaverickM3
My Ride: gets badge
Op, how about getting some zhp cams? No guess work on the small(important) details.
MaverickM3 is offline   Reply With Quote
Old 04-02-2013, 03:43 PM   #9
bigjae1976
bigjae1976's Avatar
There's a more aggressive grind than 248/256 readily available but you really should address the bottom end first if max power is the goal.
Old 04-10-2013, 05:16 PM   #10
Alun1976
My Ride: BMW Z4
Anyone have any 248/256 schrick cams for sale? What is the concern about the bottom end and how can it be remedied?
Cheers
Al
Alun1976 is offline   Reply With Quote
