Go Back   E46Fanatics > Tuning & Tech > Bavarian Soundwerks' Mobile Electronics Forum
Sponsored by Bavarian Soundwerks
Old 07-13-2003, 02:04 AM   #1
dt32569
My Ride: 330Ci
Aftermarket head unit with NO FM RECEPTION!
Ok I installed my Kenwood Excelon 589 head until back in Feb - had NO FM stations except for one, which in is town and pumps out as much power as a nuclear detonation.
I have read numerous posts - I checked the diagram which explains the pin functions on the stock harness and my radio turn on wire is connected to the power antenna wire on the BMW harness. Still..one station.
I am about to pull this damn aftermarket head unit out and buy that Sirius adapter or forget it all and reinstall the stock HU so I can have radio in the car in the mornings (for some local shows AND I live on the coast - where hurricanes hit)
Any ideas or help would be appreciated. And no, asking how much for the 859 is not help.
I saw another post where a guy mentioned an amplifier on the stock antenna was not getting power from his head unit and he mentioned a white wire? I have the VW/German adapter (schosche?) for the antenna and the wires supposedly correct.
Anyone?
dt32569 is offline   Reply With Quote
Old 07-14-2003, 09:14 PM   #2
XcvX
My Ride: 1999 328i
Send a message via AIM to XcvX
for my deck they had to install some sort of attenae thing for it to work at all
SWED
XcvX is offline   Reply With Quote
Old 07-14-2003, 11:20 PM   #3
Ron@Streeteffectz
You need an amplified antenna adapter...it sends 12volts down the center leg to turn on the factory antenna amplifier
Ron@Streeteffectz is offline   Reply With Quote
Old 07-14-2003, 11:27 PM   #4
dt32569
My Ride: 330Ci
Ok....?
Where can I get one of those? it plugs into the coax antenna cable?
This one work with ours? - VWA-2
VW Amplified Antenna Adapter
Old 07-15-2003, 01:21 PM   #5
dt32569
My Ride: 330Ci
bump
Old 07-15-2003, 01:54 PM   #6
Pmmeke
modder fokker
My Ride: E46/E92M3/E60 525d
Send a message via ICQ to Pmmeke
I have a bad reception to.
I have tinted windows, 3 amps, 4O inches of cables and wires, 2 batterys, 12 speakers, woofers ....this all doesnt help to create a radio friendly envirimont.
I added a amplified new antenna but douh it improved i still got some noise on fm.
:: Europrojektz - Belgian Chapter
:: http://europrojektz-world.com
:: http://europrojektz.be[/CENTER]
Pmmeke is offline   Reply With Quote
Old 07-15-2003, 02:00 PM   #7
dt32569
My Ride: 330Ci
Antenna
What kind of antenna did you add?
Old 07-15-2003, 02:54 PM   #8
Pmmeke
modder fokker
forgot. It a sticky front window kind. Kostet about 70 dollars i think.
Old 07-15-2003, 03:09 PM   #9
dt32569
My Ride: 330Ci
Seen those in the states here..little cheaper...dunno if it would help. I am going to try to correct it before adding one though...but thanks for the info!
