E46 Convertible
Old 03-24-2013, 03:00 PM   #1
comova
My Ride: Silver 325Cic
Broke my top
About a year ago I broke my convertible soft top by trying to close it with a backseat full of furniture and it caught and broke.
Anyone out there have a similar experience and what did it cost to fix?
Also, anyone know a good (& cheap) convertible top guy in the Los Angeles area?
"The problem with the designated driver program, it's not a desirable job, but if you ever get sucked into doing it, have fun with it. At the end of the night, drop them off at the wrong house." -Jeff Foxworthy
comova is offline   Reply With Quote
Old 03-24-2013, 07:30 PM   #2
TopHydraulicsInc.com
Supporting Vendor
TopHydraulicsInc.com's Avatar
My Ride: German verts
Bummer! Do you know which parts are broken?
Klaus
www.tophydraulicsinc.com
Some BMW E46 hydraulic cylinders, pumps, and valves that we rebuild and upgrade at Top Hydraulics:
54347025593
54347025600
54347025599
54348236956
54348243269
543454347025595 (hydro-unit, sticker p/n is 8234530)
54347025592 (control unit)
54347025598 (improved hoses manufactured at Top Hydraulics)
http://www.tophydraulicsinc.com/en/56-bmw-e46
TopHydraulicsInc.com is offline   Reply With Quote
Old 03-25-2013, 07:52 PM   #3
comova
No clue Klaus.
I did see a small piece of plastic fly out when it broke so it must have been something towards the back.
I have seen then (twice) half way opened it manually and then the hydraulics have taken over and locked it shut.
The button is also always blinking. Grrrr.
Old 03-30-2013, 08:21 PM   #4
alfa101
My Ride: 2001 325cic
If the plastic piece that flew has the color of trim, it probably came from the sliding covers on the sides - they're spring loaded and slide in when the top moves. Easy to break or snap... but easy to replace.
If you have frame problems such as bent or busted frame, than you'll need a new one I think. You can use the sot tops if they're not torn, but they'll need to be put on the replacement frame.
You can find a frame or complete setup for a reasonable price (under $1000) on eBay if you're patient and keep looking/shopping. If you busted the hydraulics than that's a bummer as that means even more work, but you say they took over so I'm assuming your plumbing is ok.
Parts are not the killer for the tops - labor is especially if the soft covers need to be replaced due to very long laborious process. Dealer charges from what I've seen up to 3-4K for a top to be replaced....
My advice: talk to a couple of canvas and upholstery people. If the problem is with the metal frame than look for a shop that deals with convertibles, not necessarily just BMWs... I have a complete M3 black top, but I'm on the other side of the country so can't be of help.
alfa101 is offline   Reply With Quote
Old 04-12-2013, 10:03 PM   #5
comova
Thanks Alfa101, I just finished DIY#1 for 2013 (CCV, OFHG & PS) I am doing shocks/struts next and before summer going to diagnose the soft top. I will keep the thread going once I get someone to peep in there and give me an estimate.
Old 04-13-2013, 01:17 PM   #6
johnrando
My Ride: '06 330 CIC ZHP
Robbins Tops in Santa Monica used to repair but now they only manufacture in Oxnard I believe. You might ask them for a shop but not sure they'd know after all these years.
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
convertible top, los angeles
