Old 03-25-2013, 07:15 PM   #1
granko007
My Ride: E46 323i
Strange sound from engine
video: http://www.youtube.com/watch?feature...&v=wMiYfDGXE7Q
Problem (chattering) begins approximately at 0:20.
RPM when problem occurs: 1500-2000.
First few times on video I push the gas pedal and the sound is OK. Around 0:20 I get to between 1500 (at that time I push the gas pedal) - 2000 (at that time I release the gas pedal) rpms and the chattering begins to be heard when releasing the gas pedal.
I will be very happy if you tell me what it could be.
I remember (about 2 years) it only when the engine is cold.
Thanks,
David_a_
granko007 is offline   Reply With Quote
Old 03-26-2013, 10:04 PM   #2
lszlszx
My Ride: 1.8T, XC70
Hi! It sounds like there could be a loose part somewhere, like a piece plastic vibrating at that rpm. Have someone press the gas for you while
you check around the engine.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 03-26-2013, 10:10 PM   #3
dambro24
My Ride: 330ci
could be valve cover rattle..but video has to be of engine bay when reving...tons of plastic parts in there.
Sent from my SPH-D700 using Bimmer App
dambro24 is offline   Reply With Quote
Old 03-27-2013, 08:55 AM   #4
granko007
My Ride: E46 323i
Thank you for replies!
I will try to check it more carefully with someone pushing the gas pedal.
David
E46 323i
engine
