How much in maintnance aprox? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 03-26-2013, 07:42 AM   #1
m3comp06
My Ride: m3 Competion pck 06
Hi guys
i just bought a very nice m3 Coupe e46 2006
with the comp pck 6 sp.
Have 65k miles on it.
What i have to expect to repair or maintain bet 65k and 95k ??
Also The front rotor and pads have been changed at 64k.
Thanks for your help!
m3comp06 is offline   Reply With Quote
Old 03-26-2013, 10:04 AM   #2
danwilz
My Ride: E46 M3 Vert 2012 X5
If Inspection two was done with the valve adj and plugs at 60 you should be free and clear to 90k besides oil changes and basic things.
If not you need Inspection II with all the trimmings.
danwilz is offline   Reply With Quote
Old 03-26-2013, 10:32 AM   #3
m3comp06
ok
because when i see comments on different forum, i'd like you spend more time to repair that you spend time to enjoy it...
But yeah the service 2 is done since 1k milles.
I just have to buy good summer tires.
What about the rear brakes?
And for the tranny manual, there something to check?
Old 03-26-2013, 08:04 PM   #4
danwilz
If you need to change the rear brakes DIY for about 250. dollars and the trans if the fluid wasnt changed at inspection II then change it its easy and do the diff fluid while your at it. As for tires Michelin Pilot super sports all day.
Old 03-26-2013, 08:07 PM   #5
m3comp06
I go withthe Continental ExtContact DW
Is supose to be good too
Old 03-27-2013, 05:12 PM   #6
Cletus74
My Ride: 2002 M3
nothing to check on the manual tranny, just drain and replace the fluid. i went with Redline from TMS
Cletus74 is offline   Reply With Quote
Old 03-27-2013, 05:16 PM   #7
Cletus74
My Ride: 2002 M3
as for tires ive had good experience with sumitomo htr zIII from tire rack. they are cheap (half price of michelins) but do the job unless you are going to the track.
Old 03-27-2013, 05:23 PM   #8
tinman831
My Ride: M3
Take a look at this thread for required maintenance at specific mileage intervals:
http://m3forum.net/m3forum/showthread.php?t=190111
Figure out how many miles are on your car and what maintenance procedures need to have been done by that point.
tinman831 is offline   Reply With Quote
Old 03-27-2013, 05:31 PM   #9
m3comp06
WoW thanks for your help guys!
I will receive the car from Ontario Canade next week!
I have never drive a m3 before,
and i bought the car with email,
no test drive. But the car is in mint
condition.
Apparently i will be extremly surprised
when i take the car for the first run!
Old 03-27-2013, 06:43 PM   #10
tinman831
My Ride: M3
condition.
Not the best way to purchase a car, but good luck.
Old 03-27-2013, 06:55 PM   #11
m3comp06
Yeah I know
But i bought the car from a BMW dealer salesman (Private sale)
And i saw all the minor esthetic
correction to do,
plus all the maintenance since new.
at the Dealer.
Its a Coupe 2006 Manual Blue
It was so hard to found the exact model.
Before to take my decision for the same i bought, I thought to import the same car from USA, but with the freight and duties ... $$$$$$$
So mine is a Canadian car with 105kilometers.
Old 03-27-2013, 08:30 PM   #12
m3comp06
Its not this car but exactly similar but Leather inside instead of clothes
Old 03-28-2013, 01:58 PM   #13
sakumaxp
My Ride: 02 M3 convertible
ive spent a little over 3K on maintenance and other little things on mine, (coilover install, inspection II, pads rotors, pulleys). mine is an 02 with 108K
Carbon Black Metallic
SMG II
Verttttt
VCSL Front Bumper
VCSL 1 Piece Splitter
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
sakumaxp is offline   Reply With Quote
Old 03-28-2013, 03:01 PM   #14
kuksul08
My Ride: M3
I spent nearly $2k in maintenance and repairs in the past year alone. It's not cheap.
Look at that subtle jet-black coloring. The tasteful thickness of it. Oh my God, it even has a 6mt.
S54 Valve Adjustment Spreadsheet & Info: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip
S54 VANOS DIY Video: http://www.youtube.com/watch?v=9SkT2j3jsU0
kuksul08 is offline   Reply With Quote
Old 03-28-2013, 03:12 PM   #15
taylor192
My Ride: 2003.5 M3
In my first year of ownership:
I've spent $300 on required maintenance (oil change, brake pads).
I've spent $700 on unexpected repairs (leaking steering hose, Vanos solenoid, convertible top hydraulic cylinder leak).
I've spent $1000 on typical 10yr/100K miles maintenance items (RTABs, FCABs, end links, struts, ...)
Overall not too bad for a 10yo car. Even though the repairs were "unexpected", they are common issues that I was aware I would have to do at some point if I kept the car long enough. I was just hoping to make it through a year without issues.
Old 03-28-2013, 10:32 PM   #16
E46 WOT
My Ride: 2004 M3 SMG
my master mechanic said you really don't need to do the valve adj on the S54 for whatever that's worth
2004.5 M3 SMG
CF CSL Trunk, CSL replica bumper, 18x9.5 BW Arc-8 w/ 245/265 R-S3s, PFC 08 pads, SS brake lines, Prospeed 683 Brake fluid, ISC N1 Coilovers, Powerflex poly RTABs, sways, and diff bushings, solid FCABs, BW performance motormounts, Rogue transmounts, BSW I-Pod Dock, Rookie BMWCCA Club Race license, 2:08.935 VIR Full Course, BW intake boot + K&N drop in filter. Borla catback exhaust.
E46 WOT is offline   Reply With Quote
Old 03-28-2013, 10:37 PM   #17
m3comp06
Even if the m3 is a beast, is there a link between abusive conduct and maintenance?
Old 03-28-2013, 10:44 PM   #18
E46 WOT
ok
I bought my 2004 SMG with 78k miles and now have 143k and about a dozen hard track days on it, only things I've needed to replace is FCAB (fun upgrade opportunity), fuel pump just recently at 141k, rear diff input seal, alternator at 130k, and a TPS. Everything else has been standard oil changes type maintenance.
What about the rear brakes are you worried about in specific? The only reason rear pads would get worn out before the front is if you drive hard with DSC on and you get DSC wearing those pads down under acceleration.
Not sure about what to be specific about the manual tranny.
Unless you track (road course) the car you can put any kind of tires on the M3. If you understand car control you can have a whole lot more fun on the streets under legal speed limits with 400 treadware all seasons than the money you shell out for premium summer tires that you'll burn up in half the time. I have friends with coilovers and supersports that can't keep up with me looping on and off ramps, it's all about driver education.
Get to a high performance driving school when you can and progressively upgrade the equipment you find limiting you- I'll place huge bets that tires are not limiting the majority of M3 owners but they think they are. Have fun with learning the cars limits (in the right environment - not on the street) and get to the expensive stuff when you'll understand how to use it. I'm saying this from experience, not a holier than though stance. Ask any club racer the same thing.
Congrats on the purchase, you'll have a blast with the car!
2004.5 M3 SMG
Old 03-29-2013, 12:21 AM   #19
sakumaxp
when i purchased mine it had 55K on the odometer, i ran it to about 90K till i had my inspection II done and to my surprise there was nothing really on its way out or going bad on my car.
SMG II
Verttttt
VCSL Front Bumper
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
Old 03-29-2013, 12:46 AM   #20
///M Powerd
My Ride: 2003.5 M3 Coupe
I've had my M3 for a year now. My GM5 module died right when I bought it. Other than that, I've just done regular maintenance. 2 oil changes, diff fluid, valve adjust, battery and replaced my shitty Achilles Tires with PSS. Total for all this was about 4.2K in a year. 1K in repairs, 1.6 in tires, 1.6 in maintenance. I'm at about 90K miles. (I'm in Canada btw and stuff is more expensive up here!)
Don't ask about the mods tho
2003.5 M3 Coupe. Jet Black/Black Nappa/Full CF Trim
Eisenmann Race 83MM Bilstein PSS10 Michelin PSS Powerflex RTABs/FCABs
///M Powerd is offline   Reply With Quote
