Old 03-26-2013, 01:43 PM   #1
SALES@RSW
My Ride: TTRS, SL65, 993
AR Designs 335i/335xi Oil Cooler Kit Stage 1 - INSTOCK **NEW CHEAP**
We have 1 system in stock, we need to move some of our old inventory, so shoot me a PM / E-mail for GREAT Pricing on this kit !
BMW_335_AR_Oil_Cooler by Redline Speed Worx, on Flickr
BMW_335_AR_Oil_Cooler_2 by Redline Speed Worx, on Flickr
Finally an optimal solution for the famous oil temperature problems the N54 suffers from. Instead of simply replacing the factory oil cooler with a slightly larger core, we leave the factory setup intact and add a SECOND core behind the kidney grilles. This not only increases the cooling capacity, but more than DOUBLES it! Our kit provides the factory oil cooler with much more airflow then what is available in the fender wells.
What is included?
Billet aluminum oil filter housing adapter - CNC'd, anodized black
Setrab Oil Cooler Core - simply the best brand in oil cooler cores available. Most of the competition use far inferior cores, resulting in higher temperatures and sometimes catastrophic failure. One of our customers previously had a competing oil cooler literally explode on the Nurburgring, splashing oil on the tires and track at over 150mph!
Anodized aluminum mounting brackets + all necessary hardware
Oil lines made from lightweight stainless braided hose, with black/nickel colored swivel fittings.
Retrofit kit available for those who do not currently have the factory oil cooler for an additional $499. This includes all the OEM parts needed.
What makes this kit superior to the rest?
Uses a well known, highly respected, quality core (Setrab)
Custom made and professionally assembled lightweight oil lines
You do not lose factory oil cooler as with other kits.
Oil cooler surface area is not just increased, but more than doubled.
Easy installation
No hacking or cutting of brake ducts.
Ability to add our upgrade kit that will allow you to run (2) Setrab cores for maximum cooling capacity!
.: Redline Speed Worx :. 908.223.7477
Tri-State's Premier APR Installation Center
German Automotive Repair, Performance & Fabrication
Shop Life - Click Me ! | We Complete Specialty Alignments !
SALES@RSW is offline   Reply With Quote
Old 03-27-2013, 07:06 PM   #2
SALES@RSW
All PM's replied !
Old 04-01-2013, 05:30 PM   #3
SALES@RSW
Pics Added !
