Tire question- 325i - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by The Tire Rack
Old 03-26-2013, 07:02 PM   #1
Snapasaurus
My Ride: 2005 325i SULEV
Tire question- 325i
Hey guys, it's time for me to get some new tires for my 325. The previous owner had a staggered setup with 205s in the front and 245s in the rear. BMW recommends 205s all the way around, yet with the tires I'm looking at, the 245s are only 8$ more per tire. Besides the more aggressive rear end look, is it worth the extra 16$ to throw wider rears on?
Thanks in advanced.
Snapasaurus is offline   Reply With Quote
Old 03-26-2013, 07:15 PM   #2
lszlszx
My Ride: 1.8T, XC70
It's a matter of personal preference. staggered set up looks great, but
you can't rotate wheels, so tires won't last as long.
Plus, if you have the stock wheels, 255 are too wide for the rim.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 03-26-2013, 07:21 PM   #3
Snapasaurus
I thought BMW doesn't recommend rotating tires anyways? And whoops, I meant 245s. That's what I have on them now, and that's what I was looking to replace with. My bad.
Sponsored Links
Advertisement
Old 03-26-2013, 07:29 PM   #4
lszlszx
My Ride: 1.8T, XC70
If the tire is too wide for the rim, there is too much tire flexion, real bad for
handling. Better to go with stock tire size, maybe plus one.
Old 03-26-2013, 07:51 PM   #5
Snapasaurus
Would you say 245s are too big for the stock 16s, than?
Old 03-26-2013, 08:13 PM   #6
lszlszx
My Ride: 1.8T, XC70
Yes, they are. I think, your rims are 7" wide, the ideal tire width is 205 for that.
There are alot of used rims for sale cheap, do some research before you buy tires. Like syle 44 which came with the sport suspension. 17x8
Old 03-26-2013, 10:55 PM   #7
saxual328ci
My Ride: 2004 325ci
I like lslsx suggestion. Buying 17in rims. I don't like the ride you get on the 16in rims.
My car has the same size tires all around and I hate it. I have 17in rims though. And when I purchased the car it came with the same size tires all around 225s. My previous bimmer that I had, the wheels were staggered.. loved it.
saxual328ci is offline   Reply With Quote
Old 03-26-2013, 11:27 PM   #8
lcoleman
My Ride: '79 Massey Ferguson
I don't know where this came from, but I think it's silly and I would ignore it completely.
Square setups are better than staggered from pretty much every perspective that I can think of except looks.
Old 03-26-2013, 11:43 PM   #9
2manytoyz
My Ride: 00 328i
i have a sedan with the sport suspension and i just put on a set of 18x8.5 et38 offset with 245/40/18 and the look and fit great.If i have 2 passengers the right rear will will rub if i go over train tracks or something.Whith that said i havent rolled the fenders.. i think i will do that tomorrow.
00 328i SS rep header & magnaflow catback(330 spec)
stern st-5 wheels-navi-sport package
5/99 build zf auto car in steel gray
00 323ci sport package 5 speed
2manytoyz is offline   Reply With Quote
Old 03-27-2013, 10:03 AM   #10
sunsetcoast
My Ride: '99 323i & '00 323iT
The "don't rotate tires" advice is in the Owner's Manual. They say, IIRC, this is b/c of different wear characteristics.
Like you, I ignore it, with rotations every 6-7000 miles. I've not noticed any overly unusual wear.
sunsetcoast is offline   Reply With Quote
Old 03-27-2013, 10:13 AM   #11
sunsetcoast
Thanks in advanced.
The question is about appearance, right? Because, for 90% of owners, a quality 205/55-16 will be more than adequate from a performance perspective.
If you have 7" wheels, then 225/50 is as wide as you should go. And a square setup all around will provide better a better balance: more grip at the back end will tend to induce understeer. Wide tires in the front will contribute to tramlining. Other things being equal, wider tires hydroplane more easily than narrower tires as well, which might be a major consideration in the PNW.
Old 03-27-2013, 10:45 PM   #12
Bimmerboye46
My Ride: 01 325i Sport
I have a 2001 325i Sport Package (rides 1" lower). I called in to discount tire to make sure the wheels I wanted to buy would fit (18X8.5 Squared +35 offest). They said I could go up to 18X9 in the front.
Point is I rolled my fenders but my R/H rear wheel still scrapes when the suspension is compressed!! The lip clears but I want to tear out the damn plastic in my wheel well!
Any ideas or suggestions!? thanks guys...
Bimmerboye46 is offline   Reply With Quote
Old 03-28-2013, 11:39 AM   #13
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
Until you post the exact rim widths and tires size I cannot say for sure, but in the vast majority of cases a 205 width tire will not fit on the same wheel width as a 245 width tire. So you may not have a choice of using 205's all around.
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 03-28-2013, 12:28 PM   #14
Snapasaurus
These are the wheels I am on. Stock non-sport package 16s. I am in class right now, so I can't check the dimensions of the wheels, but I know for a fact the fronts are 205s and the rears are 245s. I do not believe the wheels themselves are staggered.
Old 03-28-2013, 01:59 PM   #15
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Personally, I prefer square setups for the ability to rotate.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 03-28-2013, 07:15 PM   #16
lszlszx
My Ride: 1.8T, XC70
Yep, that's what I thought you'd have. I think you want it to look sporty, upgrade to 17" and then you can decide about square, or staggered setup.
Old 03-30-2013, 11:10 PM   #17
Snapasaurus
I'm just going to roll on the stock square 205 set up. I really wish I had money for a set of 17 or 18s, but unfortunatly that isn't the case. Thanks for the help guys!
Old 04-16-2013, 07:19 PM   #18
Bimmerboye46
So, after rolling my fenders until they have clearance, grinding the plastic inside of the wheel well (where the fender mates with bumper), I sill dont have clearance on the metal clip that holds the bumper to the fender! It looks like I will need body work done to flare the fender/bumper a bit, similar to an M3.
My alignment is maxed out at -3 chamber. My tires are aligned per spec but I am still having problems mainly with my rear right corner wheel well. Any ideas/solutions?
Old 04-24-2013, 05:41 PM   #19
e46bonestock
My Ride: 325
I'd stick to 205.
245/250 is too wide, more contact patch on the road, more tire roll resistance, lowers fuel economy.
So unless you tracking the car, it won't help.
Even if you do track the car, you're suspension setup will need adjusting. aka spring rate.
e46bonestock is offline   Reply With Quote
Old 04-25-2013, 08:00 AM   #20
sunsetcoast
Other things being equal, the size of the contact patch does not change. What changes is the shape of the patch. Wider tires have shorter and wider patches which is better for cornering. Not as good for some other things.
