Old 03-27-2013, 11:31 AM   #1
Cali Chase
My Ride: 2002 325i
Supercharge or engine swap
So the time as come for me to change racing classes and move up!
My reliable 325i needs some more power but I can't part with her after all we have been through. I would like to either supercharge the m54 with a stage 2 from ess OR swap in an s54. The s54 path with cost significantly more but the possibilities are endless after that. I know I will have to change the transmission and rear end with an s54. So what are everyone's opinions? I have considered a built engine but I currently don't have a full race team that will rebuild the engine after every race and never will, nor do I want to hassle with boring and stroking and engine. I feel like my 2 paths are the most realistic but keep I'm mind this is a track dedicated car, although I do drive it on the streets occasionally
**pm me for custom carbon fiber work and repair**
2007 Interlagos Blue Z4 ///M Coupe #1197 out of 1815
Porsche gt2/carrera gt cf seats l Apex arc-8s l R888s l BC Coilovers
Cali Chase is offline   Reply With Quote
Old 03-27-2013, 12:00 PM   #2
SweTurbo
Big Pimpin'
My Ride: 323i -98
you dont have to change any driveline if you dont want to
EDIT : apart from the clutch-flywheel
Old 03-27-2013, 12:38 PM   #3
FragNasty
My Ride: Car
What about all the other stuff like traction control, idrive etc etc, would you need to give that up with a swap. Is that stuff important to you on the track and your occasional street driving? Have you looked into swaps options like 2jz or LSX?
FragNasty is offline   Reply With Quote
Old 03-27-2013, 05:13 PM   #4
Cali Chase
My Ride: 2002 325i
I don't want a non BMW engine in my BMW ha. I'm kinda prejudice about other engines in my car but good thought. Yes traction control does help but would I have to eliminate that?
Old 03-27-2013, 06:09 PM   #5
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
Sell it, buy an M3. You'll thank yourself later.
Old 03-27-2013, 06:24 PM   #6
dallasberry
My Ride: ///M3
M3. You'll pour more money into doing a swap that won't run as good as an M3 for about the same money.
Custom Turbo Build By Lab22
815whp @ 625wtq 27psi E98
dallasberry is offline   Reply With Quote
Old 03-27-2013, 06:33 PM   #7
BDUB328I
My Ride: bmw 328i S54 sedan (
S54 FTW! it gives you unlimited options. it's one of the best engines ever built (motor trend motor of the year for many years) and it fits into our cars, what more could you ask for?
wont run as good? i dont understand
BDUB328I is offline   Reply With Quote
Old 03-27-2013, 06:36 PM   #8
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
I would sell and buy an m3. So many additional advantages (brakes, suspension, etc)
Coming from a guy installing an AA stage 2 in a car with 135k lol
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
Old 03-27-2013, 07:07 PM   #9
BDUB328I
this is turning into a "buy an m3" thread.
He didnt list buying an m3 as an option...
also the m3 "additional advantages" fit onto the non-m chasis, so you can swap the complete rear, stearing everything!
Old 03-27-2013, 08:34 PM   #10
Cruzader
My Ride: Alpinweiß facelift
em
Cruzader is offline   Reply With Quote
Old 03-27-2013, 08:42 PM   #11
2000_328CI
2000_328CI's Avatar
But making that swap is insanely expensive... If you already have a ton of mods, maybe it makes sense.. But if the op doesn't already have suspension, brakes, etc it won't make sense to swap it all over.
Also, there are a ton of threads about how fi on a non m isn't really a good idea. So perhaps put in the s54
Old 03-27-2013, 08:51 PM   #12
Cali Chase
My Ride: 2002 325i
I don't want to buy an m3, I already have a better suspension the. A stock m3 as we'll as a brembo bbk. In my cars form now I can keep up with an m3 in the corners not just the straights, I need the extra power. I have controlled all the other variables
Old 03-27-2013, 09:20 PM   #13
BMW_Knight
My Ride: STG2 ZHP,E70 X5(DD)
Send a message via ICQ to BMW_Knight Send a message via AIM to BMW_Knight
Come by, I will take you for a ride in my car.
Thanks to: www.getbmwparts.com www.aatuning.com www.toyotires.com
Eurowerkz Mid-Atlantic Regional Director
Join the Eurowerkz Facebook Fan Site : Click Here
Need your car coded with Euro Options? (Remote Windows up, Corner delete, DRL off, etc.) PM Me
BMW_Knight is offline   Reply With Quote
Old 03-27-2013, 10:08 PM   #14
MarcusLSB
If you want to have a car that has absolutely no resale performs just as good as a stock M3, costs more, you're on the right path.
I'd sell it, buy the M3, tune, cat delete, bolt ons.. way more reliable and better resale.
But hey, sounds like you got it all figured out.
Old 03-27-2013, 10:42 PM   #15
JDez
My Ride: 2001 330i
Swap it. Your car will handle better due to the stiffer chassis. (Assuming you have non folding seats)
Sent from my SGH-T999 using Bimmer App
JDez is offline   Reply With Quote
Old 03-27-2013, 10:47 PM   #16
FragNasty
My Ride: Car
I don't know the answer to that question. It boils down to whether you will/can use your DME to do engine management. The S54 is quite a different beast, to use your current DME you are probably looking at a reprogramming task at least. Some people may even suggest a stand-alone ECU if you decide you will want to take things even further (you lose traction control and goodies that your actual DME features in this case). But some stand-alones will give you better traction control FYI, but it won't be implemented by the BMW DME.
Remember, there are all those other features that BMW's come with besides traction control. That was merely an example.
As PEI330CI, another member here stated once, to reach a certain level of performance you will need to spend X dollars. By starting with the M3 platform, you start further along that performance road. Sure you can do the same with with a 325, but you need to put some of your sweat and blood to get to where you would be with a stock M3. Depending on your goals, you may run into an obstacle along the way that makes everything much more difficult. And in the end you will still have a 325.
What you do really depends on how far you want to take things. I would suggest researching your options better. I would want to know what it takes to get the S54 to work in your chassis. The supercharger route is a lot easier, you can probably start with a bolt on kit. You need to decide where you want to take things.
For the money spent, only you can know if it is worth it.
Old 03-28-2013, 12:07 AM   #17
ICONIKE46
My Ride: Horse & Buggy
I know this is going against what you're saying/what you want OP...BUT he is right. The M3 is a MUCH better PLATFORM all around. Think about it, you really think that you're going to swap a S54 into your sedan and that's it? Then you have to go down the custom exhaust route, and then for the additional power you just got, you have to get your subframed reinforced, etc...As everyone has stated, SWAPPING the S54 into your car will be the more "expensive" route to take.
Now to answer YOUR question...
I understand your attachment to your car, but it's really up to you. If you were going to go FI....I would go with the AA st2 HKS kit. Reason being is, the ESS stg2 kit on a 2.5l motor IMO is not worth it. For the amount of $$$ you pay, you won't reap nearly the same, more cost efficient results as the bigger 3.0l motor using the ESS stg2 kit..I think the ESS kit and the 330s go hand in hand and blow the AA kit out of the water on the 330.. But since you have a 2.5l 325...I'd personally go with the AA stg2 kit. For the money you're getting stock M3 whp (if not better than stock) and power all the way up. I've seen a couple AA kits on 325/323s and I must admit, AA did a very good job with their kit. I'm sure the 330 kit by AA is great, but IMO I think most of the FI guys can agree the twin screw is like nothing else...just not on a 325.
I would also advise you to look at a recently made thread by a user named (bigjae) as he has(d) a boosted 330ci and tracked VERY often, and he just left the FI world to buy and build a NA e46 M3. He has his reasoning behind WHY he left the FI world from a 100% TRACK oriented guy.
Hope this helps a bit. I'm no expert, I'm just giving my opinions is all to help you out. GL
BUILD THREAD SOON..IG @: ssblvck_
ICONIKE46 is offline   Reply With Quote
Old 03-28-2013, 12:43 AM   #18
lab rat
My Ride: '02 330iT
I had the twinscrew on a 325. It wasn't quite enough.
The money you lose on parting out your mods will be easily recovered by getting the right car for racing - M3.
Also coming from a guy with supercharged M54. I don't track my car. That's why I don't need the M.
Because sleeper
Old 03-28-2013, 12:42 PM   #19
joshzhp
My Ride: ZHP--Stock
Engine swap..ecu and all. Trust me.
joshzhp is offline   Reply With Quote
Old 03-28-2013, 02:57 PM   #20
invictus
My Ride: M3 (F80 & E46), S3R
I see something about racing classes... you really want to do a supercharger on the track?
CCW. Dunlop. Ground Control. StopTech. Hawk. Vorschlag. Rogue Engineering. Recaro. TCDesign. RaceTech. VAC. Motul. Vorsteiner.
Find me on track: 10/19-21 Sonoma Speedway // 11/10-11 Thunderhill
The story so far...
Fund my track car:
PM me about my: stock diffuser, stock trunk, e46 m3 part out
invictus is offline   Reply With Quote
