Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Pacific Northwest
Pacific Northwest
AK HI ID OR WA
Old 03-28-2013, 12:38 AM   #1
seattle330
My Ride: '05 330i ZHP
Anybody in Seattle done their cooling system?
I've read a few of the comments in Mango's thread about the cooling system, and want to get mine done soon as a precaution. Are any of you familiar with this process and willing to do some coaching?
seattle330 is offline   Reply With Quote
Old 03-28-2013, 01:12 AM   #2
nahtanoj
My Ride: 2004 330cic
not familiar. but nice to see someone from my area on here!
jon
nahtanoj is offline   Reply With Quote
Old 03-28-2013, 12:59 PM   #3
vtn86
My Ride: E46 M3
I've done a water pump and thermostat on a 330xi. Wasn't as hard as I expected. Everything else should be fairly simple. Best advice if you're not good at locating bolts without seeing them is to buy or use a mirror - like a dental mirror.
Modify your car for a function and purpose, not just to follow the crowd.
vtn86 is offline   Reply With Quote
Old 03-28-2013, 01:16 PM   #4
Pierce1
My Ride: 03 330xi
I live in LaConner, but I did everything but the radiator 2 years ago. I would recomend getting a shop manual, joining the CCA, tons of members in the Seattle area, and find a local independent to ask for guidance. Mechanics will help you out.
The job is pretty straight forward. The difficult part I found was getting the hoses disconnected.
Pierce1 is offline   Reply With Quote
Old 03-28-2013, 01:55 PM   #5
seattle330
Good call on the shop manual, I'll go find one on amazon and possibly look at getting involved with a local indy. Conceptually it doesn't sound too complicated, but I'm somewhat risk averse because I can't afford to have an inoperable DD on Monday if something goes pear-shaped. Did you use ramps to get at the more difficult-to reach bits, or can you just reach in and do everything from the top?
Old 03-28-2013, 08:34 PM   #6
Pierce1
My Ride: 03 330xi
The expansion tank may be difficult to get off. The main problem you may come across is that the hoses and expansion tank become "stuck" on and are hard to "unstick".
This may require some creative mechanics. And a bit of cussing too!
Old 04-04-2013, 11:36 PM   #7
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
Where are you at in Sea?
/// MODS
Old 04-04-2013, 11:38 PM   #8
seattle330
Cap Hill near Trader Joe's. You?
Old 04-04-2013, 11:40 PM   #9
Martin 03 325i
My Ride: 03 325I
Yep I am in Auburn, it wasnt a difficult, it just took a bunch of time since I made sure i took my time for each step
Martin 03 325i is offline   Reply With Quote
Old 04-04-2013, 11:50 PM   #10
seattle330
Would you be willing to walk me through it one of these weekends? I'd need to get all the parts lined up first....
Old 04-05-2013, 12:20 PM   #11
Martin 03 325i
My Ride: 03 325I
Here..check the thread I made when I got mine done..and pm if you need any more info
http://forums.bimmerforums.com/forum...g-due-overhaul
Old 04-05-2013, 01:02 PM   #12
skylane5sp
My Ride: 2002 330i 5sp
I did all but the radiator weekend before last. Easiest car I've ever owned to work on. Minimal tools required to do this job. I don't have ramps but used jack stands. It's a lot easier on the back if you raise the front end.
skylane5sp is offline   Reply With Quote
Old 04-09-2013, 12:31 AM   #13
seattle330
Thanks for the info guys, I'll try to tackle this when it's nice out one of these weekends. Martin, does the A/T replacement differ much from the M/T fix besides the radiator?
Old 04-09-2013, 12:52 AM   #14
Martin 03 325i
My Ride: 03 325I
The fan is different so you will need either a fan tool or a thin wrench to get to the bolt that goes on the fan/water pump
Old 05-14-2013, 05:54 AM   #15
letired
My Ride: Nothin'!
I'm right next to you on 15th - not at all a mechanic, but generally inclined to mechanical tinkering (mostly on stuff like bikes, pinball machines, etc). Would love to help out/learn some basics one of these weekends if you need someone to hold a wrench and swear at stuff with ya.
letired is offline   Reply With Quote
Old 05-14-2013, 11:48 AM   #16
AstroPuls3
My Ride: 01 325i
Re: Anybody in Seattle done their cooling system?
I did a full swap a couple weekends ago, radiator, thermostat, water pump and expansion tank. Most of it was fairly easy, although be careful with the lower thermostat, we broke it taking the expansion tank out, that was a 68 dollar piece of plastic I wasn't planning on replacing.
Sent from my SPH-D710 using BimmerApp mobile app
AstroPuls3 is offline   Reply With Quote
Old 05-16-2013, 01:12 AM   #17
BimmerTech84
My Ride: 05 ZHP, 98 Jeep 5.9
make sure you replace the lower thermostat since it's an auto, as it will probably break anyways upon removal (I have broken one or two doing cooling systems at work), and they can cause the car to overheat as well. I am in the UW area if you need any extra hands or tools.
-Evan
BimmerTech84 is offline   Reply With Quote
Old 05-17-2013, 02:08 AM   #18
TitaniumCranium
/// Limitless
If you want to take a drive to Sequim I'm there on weekends. I've done this a couple of times. I'm not a mechanic by trade but have enough skill to change my auto tranny to a manual and code the car. There isn't a lot on this car I haven't disassembled/reassembled.
/// MODS
Old 05-17-2013, 02:29 PM   #19
seattle330
I've found someone who can help with this, thanks for the advice.
Old 06-02-2013, 12:42 AM   #20
seattle330
Got it done today, thanks for the advice and help all. If any of you need any help with this, I can point you to someone who's well versed in this!
cooling system, seattle
