Old 03-28-2013, 11:28 AM   #1
raichean
My Ride: 2004 e46 M3 cabrio
Randomly wont start, but then starts instantly 2nd attempt?
Hey guys.. Really odd situation every so often. 04 M3, 44k miles and I have owned it now for about 6ish weeks.
Three times, get in the car and turn the key and it just cranks and cranks. If I turn the key back and try again, it will start up just like normal on the 2nd or 3rd turn over with that awesome rumble I so love.
Three times though in roughly 6 weeks. Just odd.
Any indications of a problem? Fuel? Fuel filter? Fuel pump? Something else? Where should I start?
Car is well maintained from everything I can tell, low miles and I will have it in for the big tune up and valve adjustment in 16k miles. That is gonna hurt.
Any ideas?
raichean is offline   Reply With Quote
Old 03-28-2013, 01:06 PM   #2
HakenTT
My Ride: 323i with S54
EWS system not in sync, failing ews module or K-bus
HakenTT is offline   Reply With Quote
Old 03-28-2013, 01:24 PM   #3
raichean
So... not familiar with either of those? How would I test? What are they?
Thanks!
Old 03-28-2013, 01:36 PM   #4
mystert
My Ride: 2003 330Ci
Sounds the like battery in the key is on its way out. That happened to me. Once I got a new key it was all good
MysterT Huntington Beach, CA
mystert is offline   Reply With Quote
Old 03-28-2013, 01:37 PM   #5
raichean
Battery in the key is VERY low, with about 2 foot range so that is definitely a factor.
Old 03-28-2013, 02:33 PM   #6
mystert
My Ride: 2003 330Ci
Get a new key and you'll be all good
Old 04-01-2013, 07:09 PM   #7
WALKD U
My Ride: Just Fast!
Mine does this too but i just put key in 1st then wait then go start car.
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 05-14-2013, 11:29 AM   #8
raichean
So I have my new key for the last two weeks or so, and it did it again over the weekend. Initial start attempt, cranks but doesn't start, and on the second attempt starts instantly. *grrr* Really random and happens about once every 3-4 weeks.
Old 08-05-2013, 10:10 AM   #9
raichean
Circling back on this issue as it is back and seems to be slowly growing in severity: I believe on another thread (that I cant find now) that folks were saying cam shaft sensor for this issue? What do folks think on that, and sounds like relatively easy to replace?
Old 08-05-2013, 10:16 AM   #10
ChrisRedmon
My Ride: 2002 PY ///M3
I'm sorry, but none of these people know what they are talking about. This is a common problem with the E46 M3. A new key will not fix anything. The car is cranking, it wont turn over. If it was the key. It would be completely different. In fact, i used a dead key upon purchasing the car. Still turned over fine.
You will get more insight to this on M3F.
A lot of people have narrowed it down to dying fuel pump, tune, coils, plugs. A whole slew of things. One way to lower the chances of this happening, turn the key to the on position and let the fuel pump prime. Wait for the cabin beep to stop. Then turn the car over. If mine does this it ALWAYS starts on the second attempt. Usually happens if the car has been sitting for a while. Nothing to fret about, just annoying.
2002 Phoenix Yellow E46 M3 l 6MT l Nappa l Nav l STG Coilovers 7k/8k l BMW Performance SSK l OEM ZCP's l Kirk Roll Bar l Motorsport Hardware l Besian Systems l CSL/GTR Carbon Fiber Hood, Trunk & Diffuser l Status Gruppe Sec. 3 l Custom Rear Brace l Rear Seat Delete l Coby Wheel Products
ChrisRedmon is offline   Reply With Quote
Old 08-05-2013, 10:20 AM   #11
raichean
Sounds like identical behavior.. more likely will do it the longer the car has been sitting, but if lots of start/stop running errands, it never has done so yet. And you are absolutely right, a new key made no difference whatsoever though I needed a replacement regardless just to have two available.
Old 08-05-2013, 10:34 AM   #12
ChrisRedmon
I suggest you surf on M3F. I have yet to find a 100% fix.
I mean hell, there have been people reporting this with their e46 M3 when buying it brand new! I think its just one of the quirks we have to deal with. If you find a fix, let me know!
Also, once people have gotten custom tunes/evolve they have said it hasn't happened since. For whatever reason, i'm not quite sure.
Old 08-06-2013, 04:54 PM   #13
raichean
Thanks.. I will dig through and see what I can find. I am going to try the trick first of ignition on, let the pump prime and then start (every time) to see if that makes any difference.
GREAT signature shot btw of your car.. Yellow and Red were the two colors I was searching for, with the closest yellow in Texas (I am in WA) and red in Oregon. (got the red, obviously)
