E46 Xi Forum
Old 03-28-2013, 12:56 PM   #1
Dr.frankinstein
My Ride: 01 330xi and more
Fluids?
Well I want to change the fluids in my xi. It is a 2001 330xi I want to change the transmission fluid, transfer case fluid, front and rear differential fluid. My question is what fluid does it take? I don't have an owners manual or and type of manual for the car.
Thanks in advance
Dr.frankinstein is offline   Reply With Quote
Old 03-28-2013, 01:47 PM   #2
SamDoe1
My Ride: 4cyl of fury
F/R Differential: 75w90 full synthetic gear oil. 3 quarts should fill up both.
Transfer Case: Manual transmission fluid (Redline MT-90 is a good one). Capacity is something like 0.3Qts or so.
Auto Trans: D4 ATF (Redline D4 ATF is a good one). Unsure of capacity.
Manual Trans: Manual transmission fluid (Redline MT-90). 3 quarts will fill it up and leave you with enough to change out the TC fluid.
Old 03-28-2013, 01:51 PM   #3
Dr.frankinstein
I forgot to mention my car is automatic. Has shiftronic. Manual. Sport and drive selection
Old 03-28-2013, 05:27 PM   #4
SamDoe1
Well then cross out the last line of my post...
Old 03-28-2013, 06:15 PM   #5
Dr.frankinstein
Thank you for the info
For anyone know how much trans fluid I will need?
Old 03-29-2013, 10:40 AM   #6
Dr.frankinstein
Would also like to know how much engine oil I should get as I am also changing that to.
Old 03-31-2013, 12:05 AM   #7
jmo69
My Ride: 03 325xi 98 328is
The GM trans takes 7 Liters or 6.5 qts. and the engine takes just under 7qts. Mobil One 0w-40 is a popular choice.
Hers His
2003 325xi StahlGrau metalic almost modless, just lots of new parts, wife's DD. 1998 328is lowered, X-brace, Sparco strut brace, HIDs, AEs, almost everything blacked out, my DD.
jmo69 is offline   Reply With Quote
Old 03-31-2013, 11:32 AM   #8
Kubica
My Ride: 2003 325xi
MTL or MT-90? I recommend 50/50 d4/MTL.
Old 03-31-2013, 01:06 PM   #9
Dr.frankinstein
Well I think I am going to use ams oil just because I swear by it. I wasn't sure i it called for a special fluid.
Old 03-31-2013, 03:30 PM   #10
Nateweav
My Ride: 2001 330Xi
Here is the video I found about servicing the trans.
Nateweav is offline   Reply With Quote
Old 03-31-2013, 05:10 PM   #11
e46alfonso
My Ride: 330xi MT, mustang gt
I use RL d4 atf for MT, and mtl for the TC.
Old 04-13-2013, 01:48 PM   #12
jmo69
I'm planning to do my transfer case this afternoon and I've got all three fluids on hand. Probably going to go with the Pentosin MTF.
Hers His
