E46 Xi Forum
Old 03-28-2013, 08:40 PM   #1
Tokapeba
My Ride: 2003 325xi
Where is the right place to jack from?
I've looked at a few threads and am still a little confused at to there to Jack from. Is the proper place the center of the rear crossmember?
Tokapeba is offline   Reply With Quote
Old 03-28-2013, 09:46 PM   #2
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
the ground?
/_________\
O==[][]==O
Old 03-28-2013, 09:47 PM   #3
330i ZHP
330i ZHP's Avatar
there are four black pads (behind the front wheels and in front of rear wheels) that you can use.
You can also use the rear subframe support - but try not to lift with the diff
/_________\
O==[][]==O
Old 03-28-2013, 09:54 PM   #4
e46alfonso
My Ride: 330xi MT, mustang gt
Old 03-29-2013, 10:15 AM   #5
Tokapeba
My Ride: 2003 325xi
Originally Posted by 330i ZHP View Post
the ground?
Clever
Old 03-29-2013, 11:05 AM   #6
ixtoxi
My Ride: 02 330xi, 88 325iX
From the rear, your will see a cross member immediately forward of the differential. It is the member that the control arms are bolted to. Jack goes there. In the front, there is also a cross member, but the front jack location should have a pre-installed jack pad if it has not fallen off.
ixtoxi is offline   Reply With Quote
Old 03-30-2013, 09:51 AM   #7
Tokapeba
My Ride: 2003 325xi
I still have the jack pads, but my question was really for the floor jack. I had seen one guy who showed the car needing to be jacked on the sides and boards needing to be placed under the tires to get the car high enough to get the jack under. It looked like he was putting the jack all the way back to the second cross member when he was jacking.
Old 03-30-2013, 05:02 PM   #8
Kubica
My Ride: 2003 325xi
I don't trust the front jack pad at all.
I like to jack at LR and put a stand under LF, repeat on right side, then jack center rear and put stands at rear side jack points.
Old 03-30-2013, 06:56 PM   #9
pone
My Ride: 325xit
i'm also suspicious of the front jack pad. if i'm not mistaken, it's only a slender plastic "pin" that holds it in place. having said that, i do use it to get jack stands under the side pads. and then i put a jack stand under the sub-frame tube next to the front pad as a back up.
pone is offline   Reply With Quote
Old 08-22-2013, 11:30 AM   #10
EDWAGON
My Ride: 2004 325xiT
My Jack pad in front its missing half of it, got a new one looks like the thin pin gets pushed through and the plastic piece that goes in to cross member expands to secure it ? Am I right on that?
ID:	523064   Click image for larger version
EDWAGON is offline   Reply With Quote
Old 08-22-2013, 01:09 PM   #11
330i ZHP
330i ZHP's Avatar
open door and lift with the door - guaranteed to work
/_________\
O==[][]==O
Old 08-22-2013, 01:11 PM   #12
330i ZHP
330i ZHP's Avatar
edwagon - that is the wrong pad for your car
/_________\
O==[][]==O
Old 08-22-2013, 01:12 PM   #13
330i ZHP
330i ZHP's Avatar
/_________\
O==[][]==O
Old 08-22-2013, 01:34 PM   #14
EDWAGON
I guess you don't have an xi huh? It is the right pad see link:
http://realoem.com/bmw/showparts.do?...62&hg=31&fg=05
Old 08-22-2013, 01:35 PM   #15
EDWAGON
Why don't you try it first smart Alec .
Old 08-22-2013, 01:36 PM   #16
Hogan773
My Ride: 2002 325xi
Yes. There is another post with a guy replacing that plastic pin with metal.
Where did you buy it? I'm trying to decide where to get it cheap, or whether to just use a hockey puck
Hogan773 is offline   Reply With Quote
Old 08-22-2013, 01:37 PM   #17
330i ZHP
330i ZHP's Avatar
hmmm, that isn't the typical side (2 on each side) jack pads
/_________\
O==[][]==O
Old 08-22-2013, 01:39 PM   #18
EDWAGON
I got it from Pelicanparts, added it to a larger order much cheaper then the stealership .
Old 08-22-2013, 01:41 PM   #19
EDWAGON
I use this to to lift front and put car on jack stands on the side pads.
Old 08-22-2013, 01:44 PM   #20
330i ZHP
330i ZHP's Avatar
that pad you show is on the front subframe - not the typical (which I am certain yours has) side pads
/_________\
O==[][]==O
