Sponsored by BimmerWorld
Old 03-29-2013, 12:11 AM   #1
carbon325
My Ride: BMW 325ci
Eml,traction and abs light
Ok so about a month ago while i was driving on the freeway my BMW E46 325ci dashboard lit up showing the EML, CHECK ENGINE LIGHT, TRACTION AND ABS LIGHT. I immediately pulled over and restarted my car the lights all turned off.
It was only last week where they all turned on again this time when i restarted the car my check engine light stayed on. I got the car put on a computer and received the error code D3 IDLE-SPEED CONTROL VALVE, MECHANICAL FAULT at this time i was loosing power. I pulled the icv out and it seemed faulty so i replaced it with an original OEM bosch ICV. Once this was replaced my car was running perfect much smoother then before also was going through the gears much better.
I cleared the error code and wasn't until 2 days later where my EML, TRACTION AND ABS light came back on and my car started to loose power again, i then pulled over restarted my car and the warning lights would turn off and my power was back.
has anybody got any idea why this may be happening?
PLEASE HELP!!!!
carbon325 is offline   Reply With Quote
Old 05-10-2013, 03:00 PM   #2
03E40sick
My Ride: 2003 bmw 325ci
Send a message via Yahoo to 03E40sick
Been having this problem since sep of last year!
bimmers is the way to go........
03E40sick is offline   Reply With Quote
Old 05-10-2013, 07:48 PM   #3
carbon325
My Ride: BMW 325ci
I got my codes read and it said I had a malfunction with my MAF sensor, replaced that and haven't had the problem ever since
Old 05-11-2013, 12:22 AM   #4
03E40sick
You have replaced the MAF sensor ? And no problem yet ?
Old 05-11-2013, 12:22 AM   #5
03E40sick
Could you give me the codes you had ?
Old 05-11-2013, 10:53 AM   #6
carbon325
My Ride: BMW 325ci
Yes once I replaced my maf the problem was gone
Sorry I can't remember the codes I was receiving but they were telling me that my icv and maf sensor were faulty
