Old 03-29-2013, 08:51 AM   #1
Tony Rome
My Ride: 99' 328i & '06 530i
What is this warning light?
Hello ...I own a 99' 328i auto. This warning light popped up yesterday. I checked my owners manual and its not shown.
Tony Rome is offline   Reply With Quote
Old 03-29-2013, 08:57 AM   #2
choxor
My Ride: JDM
Transmissions warning light
Old 03-29-2013, 11:54 AM   #3
Blocked Out
My Ride: Imola 330i M-Sport
your transmission needs service. could be a simple limp mode or as serious as a fried EGS.
Update the EGS and reset adaptations. This might solve the problem
Original BMW Teile ///
IMG_1725
Old 03-29-2013, 12:19 PM   #4
shadow 2
My Ride: 07 328i
No, might just be a bad battery. Don't throw money at things till you know what's wrong.
shadow 2 is offline   Reply With Quote
Old 03-29-2013, 12:38 PM   #5
Blueandwhite85
My Ride: E46
With the car on and in drive, I doubt it's a dead battery...
Blueandwhite85 is offline   Reply With Quote
Old 03-29-2013, 01:11 PM   #6
gonzo08452
My Ride: 323 and 325 5spd
Regardless, it means $
gonzo08452 is offline   Reply With Quote
Old 03-29-2013, 01:34 PM   #7
jdny516
My Ride: Oxford Green M5
good gas mileage though
National Capital Chapter #465420
2000 ///M5 ///M Registry
Oxford Green Metallic II (430) | Caramel Nappa Leather (M3CR) | BMW Individual Black Birch |
Tuning Tech Frank Smith Tune
TTFS Alpha N
SuperSprint Headers
SuperSprint X-Pipe
DINAN Front Strut Brace
Storm Motorwerks Products
2003 BMW X5 4.6iS | Black Sapphire Metallic | Black Sport | Titan Trim
2000 323Ci | TiAg | Gray | 5MT | SOLD My Progress Thread
jdny516 is offline   Reply With Quote
Old 03-29-2013, 01:41 PM   #8
My Ride: Lexus
Could be your electrical system or transmission. Does it drive weird?
Old 03-29-2013, 01:50 PM   #9
orb
orb's Avatar
My Ride: 325Ci
Did you take that picture while driving or idling? If the latter, look at the MPG, it should be full left when idling, rhetorically.
orb is offline   Reply With Quote
Old 03-30-2013, 12:52 PM   #10
Tony Rome
Can I perform the reset or am I forced to go to the Stealer? The car seems to be shifting sorta deliberate from 1st to 2nd and its also noticeable from 2nd to 3rd. It seems to be driving okay, but prior to this warning lamp, I knew that I'm in need of a refurb throttle bottle. I lost reverse and tried relacing the solenoid (TCC?). The reverse began working intermittently. I rec'd advice on the forum that my throttle body most likely needs a rebuild.
The car has 233K on it. My head gasket is going too! Need to replace stuts and springs as well. I need to drop about $2K in parts to get this thing back in shape.
Any help on resolving this warning light is greatly appreciated.
Old 03-30-2013, 04:03 PM   #11
jdstrickland
My Ride: '94 325iC & '00 323i
It is not a battery issue. It is a transmission issue.
That light means the transmission is asking for attention. It means nothing else.
Old 03-30-2013, 04:04 PM   #12
jdstrickland
With the money you need to replace sluts and springs, you need to add a pile for transvestite work.
Old 03-30-2013, 04:21 PM   #13
lszlszx
My Ride: 1.8T, XC70
You need to read the transmission fault codes.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 03-30-2013, 04:52 PM   #14
awesomechinz
My Ride: 1999 BMW 323i sedan
awesomechinz is offline   Reply With Quote
Old 03-30-2013, 05:33 PM   #15
always-there
My Ride: 2002 BMW 330I
Yea, replace the sluts and let us know if that improved your ride quality.
Old 03-30-2013, 05:42 PM   #16
wildirish317
My Ride: 2004 325Ci vert
For the money, you may want to get a newer and fresher E46. I suggest a manual transmission.
Or you can send it to HakenTT and let him put an M3 engine and MT in it for you. Cost about $4,500, plus his labor and mark up.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 03-30-2013, 06:21 PM   #17
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
My '99 has had the same light come on a couple times, the first was actually a funny story.
1. My cousin didn't believe that manual cars could turn on and off while moving (turn the ignition off, depress clutch and start again.) I told him 'I bet my automatic can even do it!' So I just put it into neutral while going 40 mph, killed the car for a second, and turned it back on. It all went fine except the trans warning light was on. I parked it and came out after the movie, and the light did not return. I was pooping my pants for the entire movie, thinking I broke the car with about 50k miles on it.
2. A couple years later, the light turned on for 1 or 2 drives, then it didn't come back.
3. A year or two after that, it was on pretty consistently for the entire summer I drove it. One day it turned off, hasn't come back in the past year or two now.
I didn't have any drivability issues whatsoever
hi its me alec is offline   Reply With Quote
Old 03-30-2013, 10:18 PM   #18
Blueandwhite85
My Ride: E46
lol. would advise AGAINST this!
Old 04-01-2013, 12:08 PM   #19
Tony Rome
I'll check the codes. I have a Peake Research code scanner tool.
Excuse all my typos in previous posts. Was typing hella' fast while rushing out the door. LOL@"Sluts".
I'm at a crossroad with this car ...I really love the darn thing, but will probably upgrade to a later model. I just got the wife a 530i. Was hoping to pay-off/pay-down that loan before grabbing another bimmer. I'd love to get a late model 6-series! ...but also like the sleek 330i's.
BTW, I pulled my battery and gave it slow charge. The warning light is now out...lol.
Old 04-01-2013, 12:20 PM   #20
lszlszx
My Ride: 1.8T, XC70
I'm at a crossroad with this car ...I really love the darn thing, but will probably upgrade to a later model. I just got the wife a 530i. Was hoping to pay-off/pay-down that loan before grabbing another bimmer. I'd love to get a late model 6-series! ...but also like the sleek 330i's. The warning light is now out...lol.
You might be right. What's your mileage? The transmission light may have also been a sign that it's time to move on to a different car.
