///M3 Forum
Old 03-29-2013, 05:20 PM   #1
03M3Dreamz
My Ride: 2003 M3 SMG Coupe
Need some help!!!
Well for starters I have an 03 M3 smg with just over 70k on the clock... My problems started a month or so back. When coming to a stop (quickly or normally) the car would just turn off, no cel no nothing! Only happened a handful of times then stopped doing it. No I have an eml light that's cuts my power to nothing and slowly trac light brake light and ses lights all come on. If I turn the car off and right back on its back to normal. Luckily the 3 times its happened I'm right by my buddy's shop and I can pull the codes...and there's quite a few of them...if I clear them only one stays. 4f(egt sensor hard fault) and the car runs great.So it happened again today and I'm at a loss for what it can be. I've check everywhere that the codes said there were issuses and came up empty handed. I'm hopping that someone will see this that has had simalar issues. I took pics of the scan tool screen so everyone can see the mass amount of codes and maybe lend a hand. Also I've tried to pinpoint what or how makes this happen and nothing works it just randomly happens. I can drive it hard or drive it nice doesn't matter, full of gas or with gas light on...idk thanks in advance!!! Any questions just ask!
Sent from my SAMSUNG-SGH-I727 using Bimmer App
ID:	497760   Click image for larger version
ID:	497761   Click image for larger version
ID:	497762   Click image for larger version
ID:	497764   Click image for larger version
ID:	497765   Click image for larger version
ID:	497766   Click image for larger version
03M3Dreamz is offline   Reply With Quote
Old 03-31-2013, 12:01 AM   #2
DtrM3
My Ride: 2002 M3
sounds like the throttle position sensor, my car did the same thing eml light and went "limp" it turned out the tps was bad and my maf was dirty, get some maf cleaner ($4) and a tps ($80) at autozone and should fix it, the tps is right infront of the itb on the front of the block. hope that helps
DtrM3 is offline   Reply With Quote
Old 03-31-2013, 12:17 AM   #3
03M3Dreamz
Well I did test the tps and it seemed to be OK but I'll look into it again...I did notice tonight while driving at a constant 45 MPH it was jerking very slightly when I would barely have to hold the throttle to maintain speed. Also the egt hard fault won't go away now but when I view what its doing/reading its spot on no issues and gives a very stable reading... thanks for the help and first thing in the am I'm going to go back and retest it and see what I find!
Old 03-31-2013, 12:31 AM   #4
Joshwa1234
My Ride: 2003 330I Sedan
Looks also like you are losing voltage between battery and everything else or your battery an alt are going south... The >18 volts means the alt is not charging while running. That said while running it should have a minimum of I think 18.5 volts so check your electrical connections and leads from the battery. GL
Joshwa1234 is offline   Reply With Quote
Old 04-04-2013, 10:03 AM   #5
03M3Dreamz
Well looks like after cleaning the MAF sensor and replacing the TPS everything is good. No lights as of now! Thanks guys for the input!!!
