Sponsored by BimmerWorld
Old 03-30-2013, 11:19 PM   #1
\\\WINGMAN
My Ride: 2004 325i
steering wheel shake
hey guys just they other day i was experiencing some violent steering wheel shake. it doesnt happen every time i drive but it gets really annoying. im wondering everyones two cents before i have a mech look at it
\\\WINGMAN is offline   Reply With Quote
Old 03-31-2013, 02:13 AM   #2
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
Does it shake at the same speed when it happens? Does it shake after applying the brakes? A little more information regarding the conditions under which the shaking occurs would be helpful. It could be a number of things ranging from your tires, to your suspension, to your brake components.
HacksawMark is offline   Reply With Quote
Old 03-31-2013, 09:00 AM   #3
\\\WINGMAN
My Ride: 2004 325i
it shakes randomly. itll shake anywhere from 20 to 60mph but then sometimes it doesnt. and sometimes itll shake then randomly stop. but then it will shake again decelerating. im probably just going to have a mechanic look at it
Old 03-31-2013, 11:31 AM   #4
HacksawMark
Most likely suspension issues going on there. Could be something as simple as struts but never heard it being that bad. How many miles on the car? Have you done any PM?
Old 03-31-2013, 11:33 AM   #5
Dave1027
My Ride: '06 IR zhp coupe
My guess is it's the wheels needing to be balanced. Sometimes you have one that's out of balance and you can rotate the wheels to isolate which one it is.
Dave1027 is online now   Reply With Quote
Old 03-31-2013, 11:44 AM   #6
McDeshen
My Ride: '99 323i
I had a similar problem when I would reach 60+ mph, I bought new wheels and the shake was completely gone.
McDeshen is offline   Reply With Quote
Old 04-02-2013, 04:24 PM   #7
martiwil
My Ride: 2001 325i
I have this problem on my e34. Mine is getting really annoying too so I will be checking it out soon. Let me know what the mechanic tells you.
martiwil is offline   Reply With Quote
Old 04-02-2013, 04:28 PM   #8
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Check tire balance. Could be a bent rim.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 04-03-2013, 11:19 AM   #9
hummer
My Ride: 2001 330CI
If it rolls smooth some of the time and then for some reason starts shaking? It's a sure sign of suspension issues and my bet is the struts are toast!
Old 04-16-2013, 05:51 PM   #10
182BMW
My Ride: 2005 330ci
1. See if the balancing weight fell off
2. Check if you have warp rotors or a calliper that's sticking
3 check the whole control arm inner ball joint outer and bushing
4. Sway bar link ends
5.tie rod assembly
6.see if you tire have uneven wear
7.check your struts
182BMW is offline   Reply With Quote
Old 04-18-2013, 05:19 PM   #11
318ise
My Ride: 318i se
I also have this intermittent problem! I have an e46 and it happens at 60-70mph only sometimes and I can't figure it out, the steering wheel shakes like you have a flat tyre then goes away.
Surely if it was a damaged wheel /tyre it would do it all the time? Iv checked all the suspension components and all I came up with is the driver side wheel was toeing in too much but I doubt that is the problem also with it being intermittent.....
Can you keep me posted on what you come up with ?
318ise is offline   Reply With Quote
