Old 03-31-2013, 02:03 AM   #1
Drayko
My Ride: 2001 BMW 325ci
Question super low output amps on alternator, super confused...
I have a 2001 BMW 325ci, I have replaced the battery and replaced the alternator 3 times and I'm still getting the same issue... It's a valeo alternator that pushes out 120 amps but each alternator I put on is only pushing out 30 amps. I can not figure out this problem... Can someone please give me a suggestion.
Drayko is offline   Reply With Quote
Old 03-31-2013, 09:14 AM   #2
jgold47
My Ride: 2004 X5 3.0
How are you measuring Amprage output? What else is going on that you are testing this?
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 03-31-2013, 09:26 AM   #3
bernie21614
My Ride: 01 330i
It's rated for 120 amps, but will only put out what it needs up to that amount. If your turning everything on on your vehicle and that's your output then your alternater is fine
bernie21614 is offline   Reply With Quote
Old 03-31-2013, 10:05 AM   #4
Drayko
I went to AutoZone and had them test it and it comes up low output. I had it tested because everytime I roll the window or do anything electrical I loose massive power.
Old 03-31-2013, 11:56 AM   #5
lcoleman
My Ride: '79 Massey Ferguson
Check your grounds. Is it putting out 14V with the engine running?
Old 03-31-2013, 01:22 PM   #6
Drayko
It's putting out all the correct voltage just not the right amperage
Old 03-31-2013, 02:15 PM   #7
lcoleman
If you have replaced 3 alternators with the same results, it's a safe bet that the alternator itself isn't the issue.
Also, if you "loose massive power" with accessories on (headlights and rear defroster), then you don't have 14V all the time.
Old 03-31-2013, 02:49 PM   #8
Drayko
Well I've come to the conclusion it's not the alternator lol. I have 14 volts at all times, I have a voltage gauge, it drops to 12 volts anytime I put my headlights on, drop my top, or use any kind of electronics in the car
Old 03-31-2013, 02:51 PM   #9
Drayko
I basically have low amperage and that's it, power is being drawn from somewhere and I dont know where? Or what's causing this
Old 03-31-2013, 02:53 PM   #10
Drayko
I disconnected my stereo system thinking that was the problem but it's not, I can't even turn my subs on... When bass hits my car shuts off... Lol
Old 03-31-2013, 03:05 PM   #11
lcoleman
Originally Posted by lcoleman View Post
Check your grounds.
...and the connections on the alternator plug.
Old 03-31-2013, 04:16 PM   #12
Drayko
Everything on or around the alternator is secure
Old 03-31-2013, 05:51 PM   #13
lcoleman
Neither of the main grounds are near the alternator. Battery neg cable and the main engine ground on the passenger side engine mount. Also, make sure the battery terminals fit tightly.
Old 03-31-2013, 06:02 PM   #14
Drayko
Well I know the ground next to the battery and next to the computer compartment area are tight. But the negative terminal is a lil loose but I can't loosen it, it looks as if it was soldiered together or like it got really hot and the nut is fused to it and won't turn
Old 03-31-2013, 06:05 PM   #15
Stinger9
My Ride: '04 330Ci
You need to eliminate a possible high resistance connection. Especially on a car your age.
Check the clean & tight condition where the two cables connect at the drug bin. Also at the starter motor.
And the engine ground strap under the car.
give us a much better description of this statement: But the negative terminal is a lil loose but I can't loosen it, it looks as if it was soldiered together or like it got really hot and the nut is fused to it and won't turn
This sets off an alert that something may be wrong here. Take some good pics for us!
Old 03-31-2013, 06:05 PM   #16
Drayko
Also does it matter if I have my amp grounded to the car body or directly to my battery?
Old 03-31-2013, 06:12 PM   #17
bernie21614
My Ride: 01 330i
You can't always trust the autozone guys to use the equipment correctly, I remember seeing a TSB about weird power draw with certain accessories and it called for some module to be replaced can't remember the details on it. Are the alternators your getting new? Double check that everything is connected correctly and is secure also check the resistance of the cable that goes to from batter to alternator there could be something wrong with it.
Old 03-31-2013, 07:01 PM   #18
Stinger9
My Ride: '04 330Ci
No doesn't make a difference.
If a high resistance connection is your problem, it is not any piece of equipment in your car drawing too much current. It is about your electrical system not supplying enough voltage because it is losing a few volts across a high resistance connection.
Get the connections tested that I suggested so we can get this out of the way and then move onto the next step.
Old 03-31-2013, 07:02 PM   #19
lcoleman
http://www.ecstuning.com/Search/Terminal/ES163623/
Edit: Directly to the battery is better.
Old 03-31-2013, 07:06 PM   #20
Stinger9
My Ride: '04 330Ci
There are more than just main grounds. And technically there is a main ground near the alternator. The case of the alternator is grounded to the engine. But we don't consider testing this because it can't go wrong with the massive amount of metal to metal tightened with the mounting bolts.
