Old 04-12-2013, 01:59 AM   #21
Tiyal
My Ride: 2002 325I
DIY looks tough
Tiyal is offline   Reply With Quote
Old 04-19-2013, 09:16 PM   #22
rkneeshaw
My Ride: 330i ZHP
I've got a wavetrac ready to go in. Not sure how I'm going to get it installed now.... if I want to make sure its done right I might have to end up shipping the whole pumpkin out to Metric Mechanic or DiffsOnline... was really hoping there would be a shop somewhere in michigan that I could find to install it, damn.
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
Old 05-11-2015, 09:27 PM   #23
rkneeshaw
My Ride: 330i ZHP
Just updating this...
There are two components of this job:
1. remove and replace the differential pumpkin from the car (any mechanic can do this)
2. replace the "open diff" internals inside the pumpkin with the LSD and seal it back up (this should be a pro with BMW diff experience)
Basically the shop estimate is 3hrs labor to remove and reinstall the differential case or pumpkin from the car.
Then expect about $400 for a professional diff builder to swap in the LSD into the differential case, and that will likely include any bearings or shims or other shop supplies.
2003 BMW 330i ZHP
Old 05-11-2015, 10:09 PM   #24
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
So have you or have you not gotten your Wavetrac installed yet ?
I would disagree with your statement in bold letters. If those parts are needed, specifically the bearings, the price will definitely rise quickly. The last time I checked, Diffsonline was charging $300 for just a set of bearings.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 05-11-2015, 10:24 PM   #25
rkneeshaw
My Ride: 330i ZHP
Just had it installed last week. Diffsonline did my install while my car was at Turner Motorsports getting the rear subframe and diff bushings replaced. They said my bearings were shot, but maybe they just rebuilt them? I am assuming new seals would be needed on a 100k mile old diff. I wasn't charged any extra. I trust that whatever they did it's as good as new.
Obviously your mileage may vary, not all shops charge the same rates and they don't all have the same rules for what is included and what isn't.
2003 BMW 330i ZHP
Old 12-18-2015, 06:54 PM   #26
Danoff
My Ride: '04 330i ZSP
I bought my wavetrac for about $1300 and got it installed for $700. Such a difference on snow and ice.
Danoff is offline   Reply With Quote
