Old 03-31-2013, 03:30 PM   #1
ANREC330
My Ride: C6 Vette & M3
Rear end clunk.
Okay so I've had my car about four months now and everything has been perfect on it. I lowered the car on ground control coil overs a few weeks back and everything was perfect. Fast forward to this past Thursday I went in to Les Schwabs for an alignment. I drove the car home(a block away) and everything was normal. Yesterday I decided to take a drive with a couple of friends and on my way there I started noticing an annoying clunk notice that sounds like it's coming from the drivers side rear. I notice the clunk when I'm slowing down going over small imperfections in the road. All is normal at highway speeds and no noise when shifting up/down. Nothing when turning quickly/hard.
I'm getting on the lift this week to check it out. I've searched and came to the conclusion of it being either.
Subframe.
Sway bar bushings.
Or Rtabs.
Would the alignment have caused any of this? It was perfect before.
Here's a video(not my car) of what the clunk sounds like.
http://m.youtube.com/#/watch?v=unE8W...%3DunE8WvtLZow
ANREC330 is offline   Reply With Quote
Old 03-31-2013, 05:25 PM   #2
Gross328i
My Ride: '99 328i
I had a similar noises, and in my case both of the rear shock mounts were completely blown out. But you think that would have caught when changing the suspension.
Gross328i is offline   Reply With Quote
Old 03-31-2013, 05:30 PM   #3
ANREC330
Yea I put new rogue engineering rsm's when I did the shocks. Ill take my trunk apart tonight to see if maybe that's what's causing it.
Old 06-20-2013, 07:46 AM   #4
dkuchta
My Ride: 325cic
Any luck with this?
dkuchta is offline   Reply With Quote
