Old 03-31-2013, 10:06 PM   #1
roverroberts
My Ride: 2000 328i 5 speed
opinion needed
So first off let me say that I have posted on this forum recently and got flamed for doing so. I am looking for an honest opinion here for an issue with my 2000 328i. After all, that is what online forums are for right?
I think my clutch is going out. I am going to list the symptoms:
1. strange rattling noise when clutch is depressed that almost completely goes away when clutch is let out.
2. a little gear slipping, this seems to be the worst in reverse
3. a little slipping also while downshifting
4. (the most worrisome one) a burning smell after driving on and off the clutch.
Is this my clutch going out....or is this something more serious. I am leaning fully toward a worn out clutch, but your advice is appreciated.
2000 BMW 328i
2008 Land Rover LR3
2001 Land Rover Discovery II
roverroberts is offline   Reply With Quote
Old 03-31-2013, 10:45 PM   #2
David McMahon
My Ride: '99 E38 740iL
do you know when Clutch was last changed? Does sound like a failing clutch though
David McMahon is offline   Reply With Quote
Old 03-31-2013, 10:51 PM   #3
roverroberts
I am not sure. The car currently has 175000 miles on it. When I bought the car it had 145000 miles and the carfax did not mention a clutch replacement.
2000 BMW 328i
2008 Land Rover LR3
Old 03-31-2013, 10:59 PM   #4
David McMahon
The old test used to be to
Car in gear with handbrake on, lift clutch if it stalls then it's ok but of course this puts more wear on the clutch which might make the difference trying to get to the shop!
Old 04-01-2013, 12:00 AM   #5
gonzo08452
My Ride: 323 and 325 5spd
Cant you just put it in, say, 4rth and perform the same test to lesten the wear? What about the flywheel? Is it recommended to replace it with the clutch?
gonzo08452 is offline   Reply With Quote
Old 04-01-2013, 02:05 AM   #6
David McMahon
My Knowledge is exhausted, I would let othe more senior members have their say I have an open Forum question pending myself.
Old 04-01-2013, 02:38 AM   #7
always-there
My Ride: 2002 BMW 330I
# 1 seems like the throw out bearings' worn out--and yea, I'd say the clutch is worn. Time for a refresh.
Old 04-01-2013, 02:40 AM   #8
Lusticles
My Ride: 325Ci
slippage? Clutch is worn
number one Audi Fan
Lusticles is offline   Reply With Quote
Old 04-01-2013, 11:11 AM   #9
lszlszx
My Ride: 1.8T, XC70
All of those symptoms are typical signs of a failing clutch.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
