Australia
Old 03-31-2013, 10:32 PM   #1
Chewy
My Ride: '03 LSB M3 Vert SMG
Ballast alternative?
Hey guys,
So I think my driver's side ballast is going. It only turns in sometimes and the frequency of it coming on is getting less now.
Now I don't know much about the lighting system so I'm going to ask the question before just buy a new ballast.
There might be none but is there a better alternative to just buying the ballast? (Ie: new aftermarket headlight unit, etc)
Just brainstorming, I really don't know.
Suggestions please.
Chewy is offline   Reply With Quote
Old 04-01-2013, 05:01 AM   #2
fgin
My Ride: e46 facelift
Originally Posted by Chewy View Post
Hey guys,
Suggestions please.
I dont think you can replace with aftermarket and still have the bi-xenon feature. How do you know its the ballast and not the bulb? Have you tried swapping the bulbs to see if the problem still stays in the same side?
fgin is offline   Reply With Quote
Old 04-01-2013, 05:38 AM   #3
Chewy
No I haven't tested it but I don't think it the bulb as it does turn on at tinges and when it does it work perfect, no flicker etc.
I guess it could be the igniter.
Old 04-01-2013, 06:06 AM   #4
fgin
I would swap the bulb first and then the igniter and see if either of it is the cause. That way you can be sure you are not throwing money at something that isn't broken. If its the bulb then spend the money on a pair of Osram Cool Blue Intense D2S 5000k. They're supposed to be a great upgrade.
Old 04-01-2013, 06:19 AM   #5
DeclanM3
My Ride: 332Ci
I have these bulbs, they are awesome!
DeclanM3 is offline   Reply With Quote
Old 04-01-2013, 04:05 PM   #6
Chewy
Swapping bulbs in the xenon seems to be a bit harder than the good old halogens.
Old 04-01-2013, 06:50 PM   #7
Worx
Euro tuner
My Ride: BMW
Not too hard, it makes it a bit easier if you move the headlight forward a little bit.
Worx is offline   Reply With Quote
Old 04-01-2013, 09:21 PM   #8
fgin
+1 Just undo the 4 bolts that hold it and move it forward.
Old 04-06-2013, 03:13 AM   #9
Chewy
Think it may be the bulb. My dad tested it worth a volt meter and didn't show a reading.
What I don't get it's if there's no reading, why does it sometimes come on and when it does it stays on?
Old 04-06-2013, 03:48 AM   #10
Chewy
And yeah that's the easy bit. Can't get the plastic off where the headlight washer is.
Old 04-06-2013, 04:40 AM   #11
fgin
Gently pry out the headlight washer nozzle and pull it enough to take out the painted trim part. Then you can unclip the the rest of the trim starting from the inside near the grill working your way out.
Old 04-07-2013, 09:37 AM   #12
Chewy
ok i switched the globe to the other side on the car and the same side is still not working, so it's not the bulb.
Is it more likely to be the igniter or ballast?
Old 04-07-2013, 01:11 PM   #13
fgin
correct. Also check connections. But not while its ON as there is high voltage running in it when ON.
Old 05-02-2013, 11:39 PM   #14
jack.chris328
My Ride: is a truck.
It sounds more like an ignitor to me but the only way to truly find out is to swap the ballast. The ballast is much easier to swap than the ignitor. To swap the ignitor you need to completely dis-assemble the headlight. Unless the headlight is a facelift coupe headlight. Lucky for you though you only have to remove the passenger side headlight seen that the ballast is on the shock tower for the driver side for an M3.
jack.chris328 is offline   Reply With Quote
Old 05-03-2013, 01:02 AM   #15
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
could you your old man for me?
Please show him this picture and ask him to identify where the conductor is:
If he points at the arc, take that voltmeter off him and buy him a rocking chair and a pair of slippers.
E46 Coupe is offline   Reply With Quote
Old 05-03-2013, 01:05 AM   #16
E46 Coupe
E46 Coupe's Avatar
Get your mate Aussie power and have him stand in front of the headlight.. then spray water a few times until the washer pops out, and have him grab it. I'm sure it's good for a few laughs as he cops a spray of water or 2 or 3 times
Old 05-03-2013, 01:26 AM   #17
Chewy
Re: Ballast alternative?
Haha I realised it's not the bulb. I swapped it and it goes off on the same side. I just bought an igniter yesterday. Awaiting arrival. Def not fitting it myself. Who knows how and wants to?
