Old 04-01-2013, 06:38 AM   #1
bimer21
My Ride: stick 325i
Weird misfiring
Hello all fanatic i have been got this weird misfiring already for a month.
Problem: every time i start my car i got misfiring on cylinders 2,5,6 codes P1345, P1351, P1352, but after car is on by 10sec misfiring go away but it only happen when i turn on the car, sometimes i need to turn it off and on again because after 10sec doesn't go away, and when i start it again start misfiring 10sec late its gone and engine runs normal.
I replace my VCG around 3 months ago but problem start just 1 month ago.
What could i do? Thanks
bimer21 is offline   Reply With Quote
Old 04-01-2013, 07:08 AM   #2
jfoj
My Ride: 330CiC, M5, X5
Read the first link below in my signature.
Pay attention to the SAP vacuum lines if your is vacuum controlled and the DISA.
Old 04-01-2013, 07:08 AM   #3
bimer21
My Ride: stick 325i
Thanks will read everything now
Old 04-01-2013, 07:46 AM   #4
jfoj
Minor possibility that the valve cover is actually cracked, however, this would be on the the last things to address as your CCV system and many other vacuum hoses likely need to be replaced first.
Good luck.
Old 04-01-2013, 07:55 AM   #5
bimer21
My Ride: stick 325i
Yeah i will perform a smoke test first, then will try to clean MAF, because I'm getting P0171 P0174 codes on cruising speed too, if everything is good and problem keep will change spark plug which they have 20k now then coils, if keep problem, DISA and VANOS, my car its a 01 325i with 150K miles, but never present problem of lack of power or idle just this weird misfiring now at start time only
Old 04-01-2013, 08:47 AM   #6
jfoj
Cold start misfires are most likely lean problems.
Smoke tests do not find all the problems. DISA issues are a clear example of where a smoke test fails, however, 1 wire connector and 2 Torx screws will answer all the DISA questions that you may have.
Could also be a fuel pump soft failure as well, check the 2nd link below in my signature.
Old 04-01-2013, 09:25 AM   #7
bimer21
My Ride: stick 325i
I replace my fuel pump and filter with my maintenance at 130k now I'm 150k, and how do i test my DISA? I'm scare if i take it out and find out its bad that i don't have the replacement for it now, so first will do smoke test and clean MAF and wait to see what happen but I'm really sure this wont solve my headache, but will try by the way! I want to thanks you, your post and you have calm me down a little thanks a lot for help men, I'll do same when you need it thanks
Old 04-01-2013, 10:54 AM   #8
Balf
My Ride: 330Ci
Hey, I thought I would give some insight on my experience with this as well. I had the same issue with random misfires and those codes for both banks running lean. I changed the spark plugs, filters.... even tried injector cleaner lol. In the end I pulled the DISA valve. Although the unit was fine, the o-ring had flattened out partially which allowed air to slip through. I ordered an o-ring from German auto solutions and that was the fix for me. No more misfires or codes. Good luck
Balf is offline   Reply With Quote
Old 04-01-2013, 11:02 AM   #9
bimer21
My Ride: stick 325i
Thanks for your comment I will take it apart inspect it and order a new O ring too, if its bad I will replace it
They sell this O ring at dealership?
And i just see another thing on my ride my MAF does not have any part number, mark or BMW logo!
Is this thing a 20$ aftermarket ebay crap? Ewww
Old 04-01-2013, 12:22 PM   #10
jfoj
323/328 DISA O-ring can be purchased at the dealer. Not the case with 325/330. See classified section or the end of the link in my first link in my signature. A member here sells the O-rings for $2 with SASE.
Old 04-01-2013, 12:22 PM   #11
Nervous
My Ride: 01 330CI 6MT ZSP EU3
I had random misfires at startup in several cylinders, having new fuel pump/filter, etc. Ended up with constant misfire at cyl 5 and this was the coil. Replaced all 6 coils and issue is gone now. The old coils (bremi) have visible burn signs on plastic cases.
Nervous is offline   Reply With Quote
Old 04-02-2013, 09:31 PM   #12
bimer21
My Ride: stick 325i
I clean today my MAF with ARC cleaner and make a smoke test which i pass it, i have any air leaks on the car, also i use seafoam and remove the brake vacuum hose and use it to clean intake manifold which i feel a difference how it runs now, i shut off the engine and leave like that after 30min of running, i leave it off by around 40min when back and start it and weird misfiring were gone now, i will post again tomorrow morning when turn it on again to see if my problem is gone, actually took some pic of my MAF which i think its aftermarket can someone help me to tell if it is, thats the only thing it says. Thanks
ID:	498492   Click image for larger version
Old 04-02-2013, 09:55 PM   #13
jfoj
Hope cleaning helps, however, do not be surprised if nothing changes.
Old 04-02-2013, 09:57 PM   #14
bimer21
My Ride: stick 325i
I wont, i know it just 25% of my problem get fix but i will keep reading your post, they are excellent, and will keep going step by step, is my MAF OEM?
Old 04-03-2013, 06:26 AM   #15
bimer21
My Ride: stick 325i
Well i was something that i just want to erase from "TO DO LIST", but yes you were right i didn't change nothing, still doing that misfiring at start but now is less, next step DISA and VANOS seal.
Old 04-03-2013, 07:03 AM   #16
jfoj
Likely the SAP vacuum line that runs around the valve cover to under the intake.
There are vacuum connections and plugs under the rear of the intake near intake port #5. Smoke test will not always pick up this issue due to the control solenoid.
Would replace the DISA O-ring and check the SAP vacuum connections and hoses very carefully.
Old 04-03-2013, 07:24 AM   #17
bimer21
My Ride: stick 325i
Yeas i did check that one too is the one that runs around the VC and the other end is on egr or something like that that connect to secondary air pump?
And DISA will contact member when get home today to see if i can get some new O ring for it to take it apart and inspect it, if my flap if broken? What should i do?
I know replace it, but i cant put it back to keep like that till i buy a new one?
Old 04-03-2013, 11:20 AM   #18
Nervous
You may continue chasing the ghost, but for some reasons you are ignoring the most probable reason: coils and their boots. Start at least with swapping coils and check if codes follow.
Old 04-03-2013, 11:25 AM   #19
bimer21
My Ride: stick 325i
Thanks but i replace then with my maintenance at 130k now 150k, and install 6 of then new OEM from dealership, but i will move then to see if misfiring change if it does i will replace then again, thanks
Old 04-03-2013, 11:29 AM   #20
scarede46er
My Ride: 2001 BMW 325i ZSP
+1 on the SAP line. That would explain the rough start but subsequent normal operation.
