Old 04-01-2013, 08:39 AM   #1
gizmoe
My Ride: 318i
Angry E46 318i 1.9 Will Not Start
\Can anyone help, My e46 1.9 M43TU engine year 2000 will not start. Ran Ok yesterday, will not start today. Put code reader and Carsoft on it no faults displayed in any modules, Checked plugs wet with fuel, checked HT leads visually ok, checked spark produced by coil on no 1 cylinder yellow spark, not blue like normal spark ignition. Engine not firing. Is it common to lose all coils at same time? thinking this is problem due to yellow spark.
gizmoe is offline   Reply With Quote
Old 04-01-2013, 10:55 AM   #2
David McMahon
My Ride: '99 E38 740iL
Tried a jump or battery pack? Any noises when turning key?
David McMahon is offline   Reply With Quote
Old 04-01-2013, 01:14 PM   #3
gizmoe
My Ride: 318i
Unhappy Tried It Mate
Had a battery pack on it, charged the battery aswell, Carsoft, Engine Check Pro and INPA say no faults, checked fuses for eng management, no prob, getting fuel at spark plugs and out exhaust (Smell), spark at plug out of cylinder (yellow isih). Engine turning, not starting tho trying to fire i think
Old 04-01-2013, 02:00 PM   #4
David McMahon
Some people lately have mentioned key barrel, starting to sound like security or electrical issue
Old 04-01-2013, 06:23 PM   #5
TitanSilverE46
My Ride: 2001 318i & 325i
Fuel Pumps are known to fail on E46s. (I have replaced on both my 325i and 318i). Like your situation, the 325i just stopped working.
Firstly how much fuel have you got. Make sure you have AT LEAST 1/4 tank.
Next remove the rear seat base and listen when you turn the key to position 2. The fuel pump should run for for 4 or 5 secs.
If you can't hear it, could be fuel pump or relay.
Have you changed fuel filter in your time of owning the car?
Come back to us once you have checked these points.
TitanSilverE46 is offline   Reply With Quote
Old 04-03-2013, 01:27 AM   #6
gizmoe
My Ride: 318i
Thanks gents sorted, Had 3 bar at fuel rail as set by bosch regulator however mate reminded me that pressure and flow are related, I law i learnt along time ago, so disconnected my fuel line before filter and check pump pressure and flow these were good. to rule out a partial blockage of the fuel filter i took it out the system by bypassing it with a piece of hose, car started first time. Happy days
Old 04-03-2013, 01:44 AM   #7
b3llum
My Ride: 330Ci
Please, say you're planning on replacing the fuel filter. They're so cheap. Especially if you don't need the pressure regulated one.
b3llum is offline   Reply With Quote
Old 05-23-2016, 12:55 PM   #8
gizmoe
My Ride: 318i
It was the fuel filter blocked plenty pressure no flow
