Old 04-01-2013, 08:54 AM   #1
gizmoe
My Ride: 318i
Angry E46 Wont Start
Hi
Can anyone help, my E46 318i 1.9 M43TU, year 2000 wont start or even fire. Ran ok yesterday wont start today. Put Carsoft software on it no faults in any module, put engine check software on it no faults. Checked spark plugs these were wet with fuel, checked ht leads visually ok, checked spark with spare plug spark was yellow?, and not blue as i would expect, Is there a common fault checked all fuses, i suspect the coil pack has gone down. ny answers
Cheers
gizmoe is offline   Reply With Quote
Old 04-01-2013, 09:00 AM   #2
Adionik
My Ride: Bavarian Panzer
sounds like starter. is it trying to turn over?
Originally Posted by Brinkley View Post
I tried to start my car without my undertray today. It exploded in a ball of fire. I put the tray back in, hoping that will fix the issue.
Adionik is offline   Reply With Quote
Old 04-01-2013, 09:47 AM   #3
gizmoe
My Ride: 318i
Red face Starter OK
Look at starter engine turning over, trying to fire but no succeding
Old 04-01-2013, 09:54 AM   #4
icecolde46
My Ride: e46
battery died. try to jump start it first.
icecolde46 is offline   Reply With Quote
Old 04-01-2013, 11:12 AM   #5
SilverMayn
My Ride: ZHP,325i,e36 m3
ok....I JUST DELT WITH THIS problem... First off before you go buy parts do you have second key? Valet key? If so try that if not get one made... I threw hundreds of dollars at my car after i rebuilt my engine. Starter /alternator etc.. nothing... Not even a click from the starter or any indication that it was trying to start... I finally looked in to the imobilizer. this was my problem. I paid 160$ to have a valet key made.. started right up!!! (wont work with my old key anymore)
FYI if your battery is dead and your try to push start the car if there isnt enough juicein the battery or if it has dead cell the EWS will erase all known transponder keys. have your EWS reflashed or get a valet key made
SilverMayn is offline   Reply With Quote
Old 04-01-2013, 01:22 PM   #6
gizmoe
My Ride: 318i
Unhappy Its turning over
Cheers Mate
Its turning over, spark present when tested out of cylinder, yellowish spark! and plugs wet with fuel, just wont start (Fire).
Old 04-01-2013, 06:29 PM   #7
TitanSilverE46
My Ride: 2001 318i & 325i
You don't need two threads on the same issue ....
TitanSilverE46 is offline   Reply With Quote
Old 04-03-2013, 01:21 AM   #8
gizmoe
My Ride: 318i
Thanks gents sorted, checked everything on car but forgot basics, I had 3 bar at rail as per regulator setting however a mate reminded me that pressure and flow are related a law i learnt along time ago. So disconnected my fuel pump output, tested pump delivery, plenty of flow and pressure, put a hose in circuit instead of fuel filter car started first time. So i had pressure but not the flow required at rail even tho spark plugs getting wet. Happy days
