Old 04-01-2013, 09:41 AM   #1
icecolde46
My Ride: e46
Smile I love german engineering
yesterday, I tried to change the engine oil. But, I broke the oil drain plug. half of the screw was left in the oil pan screw hole.
I know that there is some tool kit using a left handed drill to bore a hole on the broken screw and then you can un-screw it using a chisel.
Just before I was trying to order the tool-kit, I noticed that the oil drain plug has already a hole in the center of it. God! the genius German engineers had already known that you would broke the screw, so they have already bored a hole for you.
Then I got the broken screw out of the oil pan easily with a chisel and with a smile on my face.
icecolde46 is offline   Reply With Quote
Old 04-01-2013, 10:11 AM   #2
Adionik
My Ride: Bavarian Panzer
I don't know how so many people strip the oil bolt. Just get it in their hand tight and go from there.
Originally Posted by Brinkley View Post
I tried to start my car without my undertray today. It exploded in a ball of fire. I put the tray back in, hoping that will fix the issue.
Adionik is offline   Reply With Quote
Old 04-01-2013, 10:15 AM   #3
icecolde46
My Ride: e46
I used a wrench to tighten the screw and it brokes.
Old 04-01-2013, 10:17 AM   #4
HBizzo88
My Ride: 2002 bmw 330ci
Torque wrench! 18 ft/lbs
HBizzo88 is offline   Reply With Quote
Old 04-01-2013, 10:17 AM   #5
Teddy7
My Ride: slides
Originally Posted by lszlszx View Post
You should get a torque wrench to prevent that from happening again.
^this
Teddy7 is offline   Reply With Quote
Old 04-01-2013, 10:44 AM   #6
tock172
My Ride: '12 135i DCT
Just replace the drain plug every few oil services.
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 04-01-2013, 11:19 AM   #7
WDE46
My Ride: '13 128i, '04 330Ci
You don't need a torque wrench for that if you know what you're doing. Just "tighten" it a bit. I don't know what else to say. There's no point in putting much muscle into it. It's not structural. It just holds a seal.
Old 04-01-2013, 11:21 AM   #8
dknightd
My Ride: 2002 330 cic
You broke it putting it in? Bummer. All that fresh expensive oil going to waste. I don't know why the bolt is hollow. I assumed either to collect crap in the hollow - or to protect oil pan in case threads got seized. Never occurred to me it might be to break when inserting (assuming to again protect expensive oil pan threads). I think before I change my oil I'll buy a new drain plug. I'm not sure you should be thanking German engineering - since I don't know why they engineered it that way. It could be dumb luck.
dknightd is offline   Reply With Quote
Old 04-01-2013, 11:55 AM   #9
Peter.turner
My Ride: E46 Project
i wasn't going to say anything, but i think you need to look at what you said, i don't put fresh oil in and then put the sump plug back in.
Peter.turner is offline   Reply With Quote
Old 04-01-2013, 01:22 PM   #10
dknightd
Old 04-01-2013, 01:35 PM   #11
MercForHire
My Ride: M235i 6MT
If u love BMW engineering. You would love VW engineering even more
Old 04-01-2013, 01:39 PM   #12
Optio
My Ride: 328i
The oil pan bolt is designed with a shear head to prevent stripping out the oil pan. The bolt torque is 18 ft lbs max.
The fault lies with the OP in not reading the BMW repair procedures prior to touching the car.
Optio is offline   Reply With Quote
Old 04-01-2013, 02:08 PM   #13
Guest021715
Account closed.
Old 04-01-2013, 02:25 PM   #14
Alex323Ci
My Ride: M3 & 323Ci (sold)
wow another oil fill plug broke thread. atleast you didn't need us to tell you how easy it is to remove if this happens.
btw it's designed to break before doing more damage to the real hard stuff to fix..the oil pan threads.
Old 04-01-2013, 02:29 PM   #15
MercForHire
My Ride: M235i 6MT
that's false. The feeling of tight to a 120lb weakling and a 220 lb bodybuilder is completely different.
Old 04-01-2013, 02:37 PM   #16
HBizzo88
http://forum.e46fanatics.com/showthread.php?p=15231506
Another argument over this, really?
Old 04-01-2013, 04:26 PM   #17
Kubica
My Ride: 2003 325xi
Yeah- use a 3/8" ratchet, not 1/2".
Old 04-01-2013, 04:55 PM   #18
WDE46
Oil plug is pretty much tight by holding the ratchet at or near the head and twisting with your forearm.
If you work on machines you will get a feel for it. I have no problem not stripping the tiniest screws on a laptop disassembly to the weakest or largest bolts on my e46. I just have a feel for when material starts to yield IDK.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 04-01-2013, 05:58 PM   #19
HBizzo88
Op obviously doesn't have a "feel for it", so that's why we're advising him to use a torque wrench. Not break bolts till he finally gets it.
Old 04-01-2013, 07:49 PM   #20
WDE46
Aye agreed
