Old 04-01-2013, 09:42 AM   #1
Flaboy239
My Ride: 2004 330ci
Battery dies after 4 days of not driving.
Went and got a brand new AGM battery thinking it would help....nope. Like clockwork, after four days of being parked the battery dies. Is this a common issue or is something running that shouldn't be running? I installed a battery disconnect switch but now I have to reset my clock all the time. Pita...
Flaboy239 is offline   Reply With Quote
Old 04-01-2013, 09:54 AM   #2
G3n15z
My Ride: '00 BMW 318i
Send a message via MSN to G3n15z
It's something running that shouldn't
G3n15z is offline   Reply With Quote
Old 04-01-2013, 10:02 AM   #3
Flaboy239
My Ride: 2004 330ci
What could be running that draws that much power? What's the best way to narrow down the search and pinpoint the issue?
Old 04-01-2013, 10:10 AM   #4
G3n15z
Scan your OBC for error codes.
Old 04-01-2013, 10:15 AM   #5
Rpaulino1
My Ride: 2002 325i
This was happening to me a while back, I don't know if it drained as quickly as 4 days but definitely within a week or two. It was my final stage resistor, which kept the fan blowing while the car was turned off.
Rpaulino1 is offline   Reply With Quote
Old 04-01-2013, 10:21 AM   #6
lszlszx
My Ride: 1.8T, XC70
Like it says above, the FSR is a common issue.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 04-01-2013, 10:32 AM   #7
Flaboy239
My Ride: 2004 330ci
I'm not even sure what the fsr is or where it's located. Anyone care to explain?
Old 04-01-2013, 10:41 AM   #8
BRccKLYN
My Ride: Topaz 01 330ci
http://forum.e46fanatics.com/showthread.php?t=977434
I believe the above linked thread has a video in how to replace the FSR. I'm sure someone with more knowledge can chime in on its particulars.
BRccKLYN is offline   Reply With Quote
Old 04-01-2013, 10:41 AM   #9
haurelio
My Ride: 2001 bmw 325i
use the search button
http://www.e46fanatics.com/forum/sho...d.php?t=713544
Contact me if you need to unlock your phone.
Also can code your car
Old 04-01-2013, 10:55 AM   #10
Flaboy239
My Ride: 2004 330ci
Would it be quiet or would I be able to hear it if it were running? I have none of the symptoms with my a/c, it works fine. Just dead battery every few days.
Old 04-01-2013, 11:00 AM   #11
Schlag96
Slightly Modded ///Member
Schlag96's Avatar
My Ride: 1999 323i
Do you have anything aftermarket that draws power? like a stereo / amp / etc?
Schlag96 is offline   Reply With Quote
Old 04-01-2013, 11:00 AM   #12
Flaboy239
My Ride: 2004 330ci
No
Old 04-01-2013, 02:33 PM   #13
Rpaulino1
My Ride: 2002 325i
I guess just turn on the fan then turn the car off for a while and wait to see if the fan keeps blowing
Old 04-01-2013, 02:40 PM   #14
Flaboy239
My Ride: 2004 330ci
Was your a/c acting up or was the battery drain the only symptom?
Old 04-01-2013, 05:19 PM   #15
shovelit
My Ride: 03 325xi and 04 330x
You should connect an ammeter and monitor the rest current.
shovelit is offline   Reply With Quote
Old 04-01-2013, 05:27 PM   #16
haurelio
you dont always get the A/C symptoms, it just slowly drains your battery.
Old 04-01-2013, 06:26 PM   #17
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
Do you have anything plugged into the cigarette lighter socket? Mine continues to draw juice after turning off the car.
HacksawMark is offline   Reply With Quote
Old 04-01-2013, 08:01 PM   #18
Flaboy239
My Ride: 2004 330ci
No. Fuse was blown for awhile so it wasn't even being used.
Old 04-01-2013, 08:02 PM   #19
Flaboy239
My Ride: 2004 330ci
I'll just order one and replace it.
Old 04-01-2013, 09:13 PM   #20
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Not sure if that link covered this but do cluster test #9 for voltage next time the car is on...and check it off too...should be around 12.2 off and 13.8-14 when on. If it's not above 13.5 it's just the alternator.
Check all the cables and grounds for tightness and corrosion and pull up on battery cables, your might be tightened but not really on the terminals tight.
Upcoming comedy shows: May 20, Greenwich Village Comedy Club. 6 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
