Old 04-01-2013, 11:43 AM   #1
Mctwist77
My Ride: '99' BMW 323i
Rear end still clunking, replaced everything. Interal diff issue or axle?
Still have my rear end clunk I have replaced the following:
Subframe reinforcement
All Subframe bushings
All differential bushings
Guibo
CSB
Transmission mounts
I havent replaced my:
Motor Mounts
I notice if I spin the driveshaft there is a decent amount of play in it and when the axles start spinning and they stop I can hear a metal on metal clunk. Is this normal? Im thinking the differential has an internal issue because of the amount of play. Or my axles are bad. Any suggestions?
Photobucket
BMW 323I 5 Speed
Mctwist77 is offline   Reply With Quote
Old 04-01-2013, 11:44 AM   #2
srbija 328i
My Ride: has 262k miles
Rtab's
M@R!O
srbija 328i is offline   Reply With Quote
Old 04-01-2013, 12:00 PM   #3
Mctwist77
That would cause noise on shifting?
Photobucket
BMW 323I 5 Speed
Old 04-01-2013, 12:13 PM   #4
lszlszx
My Ride: 1.8T, XC70
You need to jack up the rear and get under the car. With the transmission in neutral and parking brake released move the driveshaft, then the wheels back and forth. You'll see excessive play at either the differential, or at the axles if those are at fault.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 04-02-2013, 03:18 PM   #5
Mctwist77
So RTAB's can cause a clunk when you shift? Im going to replace them first.
Photobucket
BMW 323I 5 Speed
Old 05-16-2013, 02:17 AM   #6
swordsman11868
My Ride: 2003 325i
Mctwist77-
Did you ever determine the cause of you clunk? I ask because I have recently developed said clunk when shifting from Neutral into Drive (only). Others have it when going into Reverse also.
When I shift into drive, besides the clunk, the back end "squats" quite a bit. I'm thinking it's my giubo at this point and probably my CSB may need replacing as well.
I inspected the rear end without removing anything and my rear bushings look fine from the outside.
I hope it's just flex disc and/or CSB as they seem not too difficult!
TIA
-Dan
I'm just here to change the world.
BMW Wiki: http://www.bimmerfest.com/wiki/index.php
E46Fanatics inspiration Robolop: http://forum.e46fanatics.com/showthr...87566&page=101
2016 Beheadings in Saudi Arabia: 92.
swordsman11868 is offline   Reply With Quote
Old 05-16-2013, 10:02 AM   #7
jasonbimmer
My Ride: 2001 BMW 330xi
could be just your diff becoming very loose over the years.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 05-16-2013, 10:23 AM   #8
lszlszx
My Ride: 1.8T, XC70
I'm afraid it is your differential.
